Need circuitry help using acclerometer — Parallax Forums
Chad SantosChad Santos Posts: 2
edited 2009-05-01 03:34 in Accessories
I am building a sensor using the Basic Stamp microcontroller and a memsic accelerometer in order to test the acceleration of a putter head throughout the putting motion. I need help with a circuit which will turn on a led with a positive acceleration in either the x or y axis. If you could provide any assistance it would be greatly appreciated. Thanks.
    edited 2009-05-01 00:03
    Which accelerometer and which stamp? You could do this with a battery and a piece of wire with a weight on it. Show us your proposed code too.
    - Stephen
  • Chad SantosChad Santos Posts: 2
    edited 2009-05-01 00:14
    It is the Memsic Dual-Axis 2125 and I'm using the BASIC Stamp 2 Homework Board. I have found a code and circuit setup that measures tilt which I think I can use but I'm confused on how exactly to run this LED off of it just for positive acceleration.
    edited 2009-05-01 00:19
    If you orient the memsic correctly you will get values for positive and negative tilt/acceleration. test for this and only light the led if you get positive values.
    - Stephen
    And quit posting messages on the same request. It's bad manners.
    - Stephen
