Zero Resistance Amp meter (ZRA) — Parallax Forums
vortexflowvortexflow Posts: 2
edited 2009-03-05 01:15 in Accessories
Hi,
I am looking for an easy way to measure milliamp current using a zero resistance method ( no Shunt).
Anybody have any idea where to look or start?
  • BeanBean Posts: 8,129
    edited 2009-02-13 18:37
    Use a hall effect type current sensor.
    These are a ring that you run the wire through. It senses the magnetic field generated by the current flowing through the wire.
    Bean.
    There is a fine line between arrogance and confidence. Make sure you don't cross it...
  • SRLMSRLM Posts: 5,045
    edited 2009-02-13 23:21
    A forum member had a bunch of current meters for sale recently, he may still have some. I'm not sure if they match your specs, but if you do some searching you may find the thread.
  • vortexflowvortexflow Posts: 2
    edited 2009-02-14 14:21
    I am not sure if a hall sensor is sensitive enough for what i am trying to accomplish. The only method i know off is using a combo of Op Amp and am ADC in a feed back loop. Also, I was reading somewhere that you can take advantage of the Basic stamp internal function to measure low current without a shunt. Unfortunately, there is not much out there to give specifics on either method.
    edited 2009-02-14 15:41
    Moving from BASIC Stamps to Sesnros forum...
    Chris Savage
    Parallax Engineering
  • BradCBradC Posts: 2,601
    edited 2009-02-26 12:30
    vortexflow said...
    Wrap the wire several times through a ferrite core with a slot cut in it. Insert the Hall Effect into the slot in the core to measure the field.
    Wrap the wire as many times as you need to get the sensitivity you need.
    Of course this is only any good if you are not worried about suppressing or interfering with AC in the wire, but it works well for very low speed or DC.
    Cardinal Fang! Fetch the comfy chair.
  • RickBRickB Posts: 395
    edited 2009-02-26 15:31
    The input to an inverting op amp is a virtual ground. Fluke uses this technique to create a lossless (zero burden) current to voltage converter for one of their 6.5 digit meters on the 20 and 200 uA ranges. You might try making a power transistor input/output op amp to see if this technique will work at higher currents.
    Rick
    Correction!!! 6.5 digits
    Post Edited (RickB) : 3/4/2009 6:59:05 AM GMT
  • datsun2literdatsun2liter Posts: 5
    edited 2009-03-04 00:30
    Similar question, I'm using a Energy Detective to measure household energy use. I'd like to monitor individual circuits in the house main panel. A Propeller would have enough inputs to monitor all the important stuff. If I put a coil of wire around each "hot" wire, how can i measure current with a basic stamp? Once you standardize the coils you could see how much power each line is using.
    These kinds of devices are designed to measure current. [noparse][[/noparse]url[noparse][[/noparse]http://www.google.com/search?q=hall+effect+current+sensors&rls=com.microsoft:en-us&ie=UTF-8&oe=UTF-8&startIndex=&startPage=1
    - Stephen
