Sn754410 — Parallax Forums
Sn754410
enkeienkei Posts: 23
edited 2008-09-20 15:50 in BASIC Stamp
how to wire the SN754410 half-H driver to the DC motor?
    edited 2008-09-20 15:43
    You need two halves to make a whole. There should be an example schematic in the products PDF file somewhere on the internet.
    If a motor is using only one half H, it will only turn in one direction.
    It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
    Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
    edited 2008-09-20 15:44
    Do a Google search for "SN754410" and you'll find plenty of suggestions.
    One is www.hobbyengineering.com/appHBridge1A.html
    I would follow the instructions that either came with the part or the datasheet.
    - Stephen
    This may help.
