wz/if_z not doing what I expect
SSteveSSteve Posts: 808
edited June 2006 in Propeller 1 Vote Up0Vote Down
Given this code:
DAT
              mov test_reg, test_value          wz
        if_z  mov wait_time, long_wait_time
long_wait_time          long    $C000000
short_wait_time         long    $A00000
wait_time               res     4
wait_reg                res     4
test_value              long    $FFFF_FFFF
test_reg                res     4
The line that begins with "if_z" shouldn't execute, right? When I run the code, it does. The complete program is attached. if I replace "test_value" in the excerpt above with "#1", the line that begins with "if_z" (as expected) doesn't execute.
What I think is happening is that the mov statement above moves the value $FFFF_FFFF into test_reg. Where am I going wrong?
OS-X: because making Unix user-friendly was easier than debugging Windows
My band's website
Our first album on the iTunes Store
Ryer Island: our second album...
  • 4 Comments sorted by Date Added Votes
  • CJCJ Posts: 470
    edited June 2006 Vote Up0Vote Down
    all of the predefined data, needs to be before the reserved space, the modified code is attached
    Who says you have to have knowledge to use it?
    I've killed a fly with my bare mind.
  • BeanBean Posts: 7,812
    Steve,
    · I had made the same mistake, and couldn't figure it out either.
    · Look through the "Tricks & Traps" document, it has alot of good info.
    Bean.
    Cheap 4-digit LED display with driver IC·www.hc4led.com
    COMING SOON "SD DATA LOGGER" www.sddatalogger.com
    "I reject your reality, and substitute my own." Mythbusters
    logo.png?91518163160380889
    Esterline Research & Design
    thitt@esterlineresearch.com
    We offer consulting on the following areas of expertise:
    Frequency Control - Micro-Controller/Processor Projects
    Test and Automation - General Programming and Coding
    Circuit Design - Board Layouts
  • SSteveSSteve Posts: 808
    Thanks, CJ & Bean. I don't know how I managed to miss the Tricks & Traps document. I guess that was before I started reading the Propeller thread. What a life saver! I already managed to learn two of the Tricks the hard way. smile.gif
    My band's website
