Where is the I/O? — Parallax Forums
Where is the I/O?
Eric REric R Posts: 225
edited 2006-05-13 05:34 in Propeller 1
Ok, this is only my 2nd day of really working with the propeller and I have started reading the manuals (about 100 pages so far).
With the BS2 it was easy to find the I/O in the program but I am lost with the propeller. I am running the Graphics_Demo.spin and had it not been for a picture Showing what pins were in use, I am not sure I could have found it in the program. Where is it? A search for 13 shows no results, however, I have a resistor connected to this pin.
Why do I get the feeling that it is right in front of me...
  • SSteveSSteve Posts: 808
    edited 2006-05-13 02:07
    OUTA is used for I/O output. INA is for input.
    OS-X: because making Unix user-friendly was easier than debugging Windows
    edited 2006-05-13 03:19
    The Graphics Demo uses the TV Object to output the actual image data.· In the TV Object look right at the end of the source in the section called, "Parameter descriptions" for the clues you need.
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
  • Eric REric R Posts: 225
    Thanks Chris,
    I see where you are talking about and I didn't even think·twice about the TV object as both·it and the mouse gave I/O descriptions but the·Graphics_Demo code did not.·I will need to do more reading and less looking·at the demo code.
