Will this RS-232 to Bluetooth Adapter work for programming ? — Parallax Forums
miniBotminiBot Posts: 11
edited 2006-02-21 23:08 in BASIC Stamp
·Also, Will I need a NULL modem adapter ?
http://www.neteon.net/prod.asp?pc=107&p=144&pcn=Serial%20to%20Bluetooth
Post Edited (miniBot) : 2/21/2006 11:17:15 PM GMT
    edited 2006-02-21 23:01
    Please do not post duplicate messages, this is identical to the one posted in the Robotics forum. Refer to the Forum Guidlines for rules on posting (rule 6).
    ·1+1=10
  • miniBotminiBot Posts: 11
    Couldn't decide on where to post it...Robot or Stamp...I deleted the Robot one...
    I also found one more:
    Pin 9 SRI Optional power input (3.3 to 5.0 Vdc)
    If so, how do you get 5v to the pin9 of the RS-232 on the Stamp II ?
    Power Mechanisms
    The CSA operates from DC power and can be powered via one of two mechanisms:
    Supplying DC power to the power jack:
    - The acceptable supply voltage for normal operation ranges from 3.5 to 5.5 VDC, with an Absolute Maximum of 5.6V.
    - The Power supply must rise to its final voltage in less than 1mS.
    - For specifications of the power jack's physical connector, refer to SMK part # LGP3131-0111 at http://www.smk.co.jp.
    From Pin 9 of the DB-9 Connector: The acceptable supply voltage ranges from 3.5 to 12 VDC (Absolute Maximum 12V). The CSA was not intended to be connected directly to a vehicle's electrical system although a cigarette lighter adapter/DC charger is permissible.
    http://www.socketcom.com/product/CS0400-479.asp?View=Specs
