Turning a Mosfet off — Parallax Forums
SteveDSteveD Posts: 64
edited 2005-04-19 13:40 in Learn with BlocklyProp
When 5 volts is applied to the mosfet through pin 7 of the DS1620 the relay is energized.· When pin 7 turns off, the relay is still energized.· Is it ok to use the 10k resistor like I have in my drawing?· It does work but I do not know if this is the correct thing to do or not.
  • MacGeek117MacGeek117 Posts: 747
    Yes, it is.
    bugg
    Boe-bot: $229
    Toddler: $249
    Learning Google is your friend: priceless
