Resistor lookup? — Parallax Forums
Resistor lookup?
kochirokochiro Posts: 9
edited 2005-02-15 15:39 in General Discussion
Hi,
I have several resistors that were given to me in a box of parts and I do not know what they are. Is there a way to find out what they are from a website or something? I don't have the manufacturer name.
The first one is a flat light blue color with 4 solid color bands on it, they are red, green, silver and gold in that order.
The seond one looks more like a capacitor in shape (flat ends, not tapered), it is black and has a silver band on one end and has 'MEC' on one line and then on the next line it has '1N4001'.
Jay
  • MacGeek117MacGeek117 Posts: 747
    edited 2005-02-14 14:34
    Check with a DMM(Digital Multi-Meter)on Ohms to check if it is a capacitor or a resistor.
    bugg
    I think I know what I'm doing...
    ...Maybe...
  • SPENCESPENCE Posts: 204
    edited 2005-02-14 14:46
    Go on harbor freight.com and look for their on sale digital multimeter $2.99. Orange in color.
    It is a good unit. I know of 10 in this immediate area. One in use over 4 years on the original 9 v battery.
    It has all the common scales you will probably need for years to com.
    The 1n4001 may be a diode. If so, the silver bar across one end is the cathode.
    73
    spence
    k4kep
    edited 2005-02-14 14:49
    SPENCE is right, the 1N4001 is I think a high-PIV(Peak Inverse Voltage) diode.
    bugg
    ...Maybe...
    edited 2005-02-14 16:31
    http://xtronics.com/kits/rcode.htm
    red green silver gold = 0.25 Ohm +/- 5%
    the black with siver band is a diode: http://rocky.digikey.com/WebLib/On-Semi/Web%20Data/1N4000%20SERIES.pdf
    typically used for rectification purposes
  • kochirokochiro Posts: 9
    edited 2005-02-14 16:33
    Thanks everyone.
    Paul that is exactly what I was looking for, thanks.
    Jay
  • Mark GMark G Posts: 11
    edited 2005-02-14 19:45
    The black with a silver band marked 1n4001 i believe is a diode....
    edited 2005-02-14 19:48
    Mark,
    Yes it is, the link rocky.digikey.com/WebLib/On-Semi/Web%20Data/1N4000%20SERIES.pdf that Paul provided gives the exact specs of it.
    Jay
    edited 2005-02-15 01:14
    As for the question about telling the value of a resistor by the color bands, there is already another thread about this.
    http://forums.parallax.com./forums/default.aspx?f=5&m=63033&g=63037#m63037
    --==<{Chris}>==--
    Sorry I didn't search Chris. I was honestly thinking too 'small picture' in a way I guess. I totally forgot about the standards of the color bands and was thinking on the manufacturer level. That's they way things are in the fields I normally deal with so I guess that's why I didn't think about the standards.
    Jay
