does anyone know what these are called?
Hello,
I'm in need of another one of these. They seem to be female or male serial connecters, except they're very light weight; andthe wires come out of the back. Does anyone know what they may be called?
You can find some here:
http://www.jameco.com/webapp/wcs/stores/servlet/CategoryDisplay?storeId=10001&catalogId=10001&langId=-1&categoryId=11006
Chris Savage
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
Wow, I can't believe you noticed I had both male and female connectors. Nice eye.
The connectors in your picture are wider (front to back) that solder cup connectors - they're designed to accept a crimped pin. The assembly process is you would a pin on each wire and pin is inserted into the back of the connector. Small tangs on the pin lock the pin in place on the connector. In my experience, the crimped connectors are quicker to assemble - and there's no chance of a short because you're not using a soldering iron.
Radio Shack also has these in stock, but they a tad more.· But if you need them in a hurry...And, they have the pin insert/extractor tool for the crimp-pin versions.
Chris Savage
Knight Designs
P.O. Box 97
(607) 535-6777
Thanks guys!
A user pointed out to me that this is incorrect.· In fact the DB title belongs solely to the 25-pin connector.· In order to not confuse the original poster or anyone, I will simply say that these are probably best referred to as:
n-pin D-Subminiature Connector, where n is the number of pins.· In some cases it also helps to specify high-density when appropriate.· For example a VGA connector is a high-density 15-Pin D-Sub connector since it fits in the housing of a 9-pin, and bears the same D-lettering as a 9-pin.
I appreciate the heads up.
Chris Savage
Knight Designs
P.O. Box 97
(607) 535-6777
http://epl.meei.harvard.edu/Engineering/d-subminiature.html
But, I'm sure the world will continue to call 'em DB-9's....
For your inanity,
-Rusty-
Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
