Help With Homework Board Compatibility Issue — Parallax Forums
mitchgaffmitchgaff Posts: 3
edited 2005-01-27 18:14 in Learn with BlocklyProp
I have been working on trying to get the article written by Jon Williams in Nuts And Volts
to interface a ps2 controller for weeks ofcource to no avail. skull.gif I called parallax and
HelpGuy said...
The Homework board has 220 ohm resistors in each of the outputs and may be causing the setup to malfunction
idea.gif I try it without the 220's in the circuit and nothing happens! skull.gif
But to get to the point, has anyone succesfully used a psx controller with a HomeWork Board? And if not... does anyone else know a way we could controll the robot
The robot is for Sience Olympiad's Robobilliards competion.
ps: I have used 2 different SONY DualSHOCK controllers
pss: The needed amount of buttoons are 4 drive buttons 6 arm buttons
Mitch Gaffigan
St. Pat's 7th Grade
DMT Data Management
    edited 2005-01-18 05:07
    That article is popular today ... I spoke with a customer by phone who was also having trouble with that project. He contacted me later to tell me that he found a broken wire. I feel pretty confident in the circuit and code -- double-check your connections. And the 220-ohm resistors on the BOE are not the problem, I am quite certain of that.
    Jon Williams
    Dallas, TX· USA
  • MatthewMatthew Posts: 200
    edited 2005-01-18 06:13
    Hey! Science Olympiad?! Robo Billards?! Haha. That's my favorite event! Back to back gold medals, and state records! 47 seconds! Now as a 10th grader, I'm Div. B's assistant coach.
    Why are you using microcontrollers for the event?
  • mitchgaffmitchgaff Posts: 3
    It was da clock
    The inversion transistor was producin a bad wave!
    I got a ttl hex inverter and it worked perfectly
    the microcontroller allows us to preprogram arm positions.
