DPDT??? — Parallax Forums
DPDT???
MatthewMatthew Posts: 200
edited 2005-01-16 03:29 in General Discussion
Hello. I recently purchased these DPDT switches from www.allelectronics.com. These to be exact:
http://www.allelectronics.com/cgi-bin/category.cgi?category=700325&item=PB-94&type=store
I was hoping it would close or open a ciruit based on its position (up or down). Unfortunetley it's not working as expected. Anyone know what's wrong?
Thanks.
  • KenMKenM Posts: 657
    edited 2005-01-15 05:43
    What exactly is the switch supposed to "switch"
    I suspect there is a simple wiring error?
    Ken
    edited 2005-01-15 06:33
    A DPDT has the following configuration (you may know this)
    A ___
    ····· \___ C
    B ___· :
    D ___· :
    ····· \___ F
    E ___
    the dotted line ([noparse]:)[/noparse]·signifies that the switching elements (represented by \) move in unison. A multimeter will confirm this.
    typically the pins will be organized like this (using terminal·letters from above)
    A C B
    D F E
    Again by testing the resistance with a multimeter will verify if this is the case. The resistance between any of the top·pin and a bottom pin will be near infinite and vice versa, the resistance between·A and B, as well as D and E will also be near infinite. C with A or B will depend on the switch state, the same holds true for F with D or E.
    Paul
  • MatthewMatthew Posts: 200
    edited 2005-01-15 07:26
    Okay, got it working, thanks guys!
    I was going to mention, I don't think the pins are set up as you might expect...Incidentally, I got the same switches from:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=58166&item=3866868406&tc=photo
    10 PCS for $.99 ...Not a bad deal...
    Chris Savage
    Knight Designs
    324 West Main Street
    P.O. Box 97
    Montour Falls, NY 14865
    (607) 535-6777
    Business Page:·· http://www.knightdesigns.com
    Personal Page:··· http://www.lightlink.com/dream/chris
    Designs Page:··· http://www.lightlink.com/dream/designs
