Hardware..as in, spacers, screws, nuts, etc.
DonW
I use several sources for small #2 thru #6 hardware...all have their plusses and minuses..and most of the time, I have what I need without ordering.
But..of late, I've needed to replenish the supply, and would like to get any recommendations for sources for this kind of hardware...seems like weeding thru several pages of several catalogs is getting more and more the norm..and would prefer a one stop source to avoid that..
Try to get ahold of one of their printed catalogs. Amazing.
Tracy Allen
www.emesystems.com
I have them on my 'favorites" list already, so I must have looked at them at one point or another..definitely need to take another look..
Chris Isaacson
I wish i knew how to put a pic here! Oh, well!
I found a good deal for an assortment of hardware thru Digi-Key...and mcmaster is even more amazing if I want to go that route...
Cheers,
Jim
www.fastenal.com
They have hundreds of stores coast to coast and specialize in fastening devices from #2 through 3-4 inch diameter bridge bolts that weigh 10 lbs.
If they dont have what you want in stock, they can get it overnight to the branch store. At no extra charge to you.
The drawback is everything is sold in· bags of 100's. But then 100 #2 screws may only cost $1.50.
The prices are usually better than Digikey.
And no I do not work for them or Digikey, but they are in my favorite group of vendors.
Check them out.
Alan Bradford
Plasma Technologies
And the request for the smallparts.com catalog has already been submitted..
Thanks for both of the recommendations.
Look up "hardware" in the index..then screws
The slotted kit·· is 1600-KIT-ND· and the philips head is 1602-KIT-ND.
There are also kits that skip the 2-56 and 4-40 and extend to 10-32.
I have spent a fortune at Small Parts getting a complete set of Stainless steel screws for my lab.
DrWass2
I'm actually trying to hunt down some #0-60's (I think 60's) for replacing some screws in a digital camera I had to fix.· Them buggers put those 'security' screws in (instead of a 4point philips style, it was a 3 point)....had to drill them out and now I don't have screws! [noparse]:p[/noparse]
Anyhow, don't be shy of using the secret Canadian screw!· The Robertson! [noparse];)[/noparse]
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
Post Edited (Paul Baker) : 1/10/2005 11:09:39 PM GMT
Small Parts lists 1-64, 0-80 and 00-90.
There is a chart of standard screw sizes at www.engineersedge.com/screw_threads_chart.htm and they also list 1-64 and 0-80. Unless they custom made their screws, you may have the pitch wrong. Or maybe there is a different set of standards out there for that kind of thing.
Jim
Jim: My boss is a hobby train enthusiast and brought in his 'small' set of screws.· I compared one surviving screw to his 0-80's and although there were the right 'barrel' size, the pitch was way off.· More like a wood screw than a machine screw.· Granted, these screws just went in to plastic, so they were much more coarse!
Steve
Ok, I know the type you mean. You might try www.smallparts.com/products/descriptions/TX.cfm and see if they'll thread in. It depends on how brittle the plastic is as to whether they'll just cut new thread or not. OTH, $13.50 for 10 screws is a little pricey just to see if it'll work.
Jim
