Demonstrating the R-2R Resistor Analog to Digital converter — Parallax Forums
tempesttempest Posts: 10
edited 2004-12-22 06:42 in Learn with BlocklyProp
Write a program to produce a number of different waveforms through the D/A converter. The waveforms will include:
1)················ triangle wave······························ 2)·· Positive ramp sawtooth
3)················ Negative ramp sawtooth··········· 4)·· Square wave
Begin with any waveform you wish and use a normally open pushbutton to step through the 4 different waveforms and then start back at the first one again. The frequency of the waveform is not important and it does not have to be variable. Apply the D/A Vout to an oscilloscope that has been set to the appropriate input voltage level and horizontal sweep rate to view the waveforms.
The LCD will still be connected to the Stamp in 4-bit mode. Each time the normally open button is pressed and a new waveform is produced, the LCD will simply display the title of the waveform type being outputted.
ok I dont know any thing about A/D converters, anywhere that I can look to find out about it?
    edited 2004-12-22 03:07
    Google "R2R network" -- you'll find lots of information.
    Jon Williams
    Dallas Office
  • edited 2004-12-22 06:42
    If you are demonstrating an R2R network, Chapter 4 in·Basic Analog and Digital has some background information and examples you might find useful. It's available for free download from www.parallax.com -> Downloads -> Stamps in Class Tutorials.
    Post Edited (Andy Lindsay) : 12/22/2004 6:44:00 AM GMT
