Clreol? — Parallax Forums
Clreol?
Keith HiltonKeith Hilton Posts: 150
edited 2004-12-10 19:46 in Learn with BlocklyProp
tongue.gif·I am in class at OTC right now, trying Jon Williams suggestion of the following program on a BS-2 and it is telling me CLREOL is a undefined symbol, it also told me hertz was a undefined variable.· I made herts VAR word above the program.· Can't find the term CLREOL in my Basic Stamp Manual.
Sorry, the teacher is gone to Florida and I need help.
Here is what Jon sugested:roll.gif
Main: Count 0, 1000 hertz
DEBUG, HOME, DEC hertz,CLREOL
GOTO Main
Post Edited By Moderator (Jon Williams) : 12/10/2004 5:55:47 PM GMT
    edited 2004-12-10 17:58
    Make sure you're using the PBASIC 2.5 declaration in your program:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    You can find CLREOL in the help file which is newer than the manual -- make sure you have the latest version of the BASIC Stamp editor (you can download it from our web site).
    Jon Williams
    Dallas Office
  • Keith HiltonKeith Hilton Posts: 150
    edited 2004-12-10 18:17
    Thanks Jon. Here is my program:
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    hertz VAR word
    Main: COUNT 0,1000, hertz
    DEBUG HOME,DEC hertz, CLREOL
    GOTO Main
    I am feeding in a signal from a function generator--sign wave set at 1K hertz.
    The 1K hertz signal is sent to a LM324, then to a 74HC14, then to BS2. The DEBUG screen is reading 3000 hertz. Jon, why isn't the DEBUG screen reading 1K hertz?
  • allanlane5allanlane5 Posts: 3,815
    edited 2004-12-10 18:27
    It should be reading 1000. Possible bugs:
    1. You don't have a common ground.
    2. You have 'ringing' on the line.
    3. Your sine wave is not zero-referenced.
    4. Why send the 1 KHZ signal to an LM324 op amp? For buffering?
    5. What does your function generator expect its signal to be terminated by. Typical value 50 ohms.
    If you're using a BS2 (not a BS2sx or BS2p), then the problem must be with your hardware -- I ran your code on an NX-1000 and got correct results from the pulse generator. You should look at the signal (on pin 0)·with a scope to see what's going on.
    You can add this to the top of your program to make it work the same with any BASIC Stamp 2 module:
    #SELECT $STAMP
      #CASE BS2, BS2E
        DurAdj      CON     $100            ' / 1
      #CASE BS2SX
        DurAdj      CON     $280            ' / 0.400
      #CASE BS2P
        OneSec      CON     $37B            ' / 0.287
      #CASE BS2PE
        OneSec      CON     $163            ' / 0.720
    #ENDSELECT
    Capture         CON     1000            ' 1 second
    Then you would adjust your COUNT line like this:
      COUNT 0, (Capture */ DurAdj), hertz
    Jon Williams
    Dallas Office
    Post Edited (Jon Williams) : 12/10/2004 6:30:31 PM GMT
    edited 2004-12-10 19:02
    Jon, miricles happen all the time! Here is what I did and the program is running perfect for me now.
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    hertz VAR word
    Main: COUNT 0,1000,hertz
    DEBUG HOME, DEC hertz /2, CLREOL
    GOTO Main
    Don't why it works but it works? I am now going to put the LCD in the program.
    Then when I go home ,I am going to hook up my guitar to the same place I hooked up the signal generator. By the way allanlane5, thanks for trying to help. I don't need the LM324 with the signal generator--you are right about this, but I will need it with my guitar, because the signal from a magnetic pickup is weak. Jon wonder why this works?
    edited 2004-12-10 19:20
    Danger Will Robinson!
    You really should know why it works before proceeding -- you may be bitten by your ignorance later. Connect a 'scope to see what you're actually getting into the BASIC Stamp for the COUNT function.
    Also, can you post your schematic for others to consider?
    Jon Williams
    Dallas Office
    edited 2004-12-10 19:21
    Got the LCD working also, here is the program add in: SEROUT 8, 16468, {254,1]
    SEROUT 8, 16468, [noparse][[/noparse]DEC hertz /2, "HZ"]
    GOTO main
    Now if I can get get my guitar to work and read out hertz on a picked string, so I can tune to the hertz I want. Got to thinking I was stupid for a while, maybe there is some hope for me Jon.
    edited 2004-12-10 19:37
    Jon, I suspect the problem is in my hookup arrangement of the LM324.· I looked at the output of the LM324·on the 0-scope before the signal got to the schmitt trigger.· It did not look even like it should, it looked doubled up.· This may be why I am getting 2 times the signal.· I will have to check the data sheets on the LM324, maybe the function generator is driving it to hard.tongue.gif
    What I believe may be happening is that your LM324 circuit is acting like a full-wave rectifier, so you're getting both halves of the sine cycle, effectively doubling your frequency. This could prove useful -- IF you know that this is a constant behavior. If your input is actually twice the source frequency, you can update your LCD at twice the rate:
    COUNT 0, 500, hertz
    Since your input frequency (to the BASIC Stamp) has been doubled, you only have to sample for half the time.
    Jon Williams
    Dallas Office
