Dimension array — Parallax Forums
Dimension array
johngaliskyjohngalisky Posts: 2
edited 2004-11-04 01:18 in Learn with BlocklyProp
How do I dimension an array in PBASIC?· I need to keep track of the order in which buttons are pushed and I think I want to do it with an array.
  • edited 2004-11-04 01:18
    In your BASIC Stamp Editor, click Help, then select Contents. When the PBASIC Syntax Guide opens, click the search tab, type in array, then click the search button. There's some pretty good information about arrays in the Memory Organization section along with some example code.
