Best way to store a string in a SPI Eeprom?
ArchiverArchiver Posts: 46,084
In the App-kit 8K-Eeprom program, the BS2 writes and retrieves a
value from a given address.
Is there a fast code of sending a whole string (not passing the
block off course) and then retrieve it the same way?
I use BS2p.
Thanks for some solutions.
  • 7 Comments sorted by Date Added Votes
  • ArchiverArchiver Posts: 46,084
    edited August 2003 Vote Up0Vote Down
    Since you're using the BS2p you might consider a change to I2C memory,
    as the built-in I2C commands will simplify EEPROM access.
    -- Jon Williams
    -- Applications Engineer, Parallax
    -- Dallas Office
    Original Message
    From: stein_frostad [noparse][[/noparse]mailto:Stein_Frostad@m...]
    Sent: Saturday, August 09, 2003 5:16 PM
    To: basicstamps@yahoogroups.com
    Subject: [noparse][[/noparse]basicstamps] Best way to store a string in a SPI Eeprom?
    I use BS2p.
    To UNSUBSCRIBE, just send mail to:
    basicstamps-unsubscribe@yahoogroups.com
    from the same email address that you subscribed. Text in the Subject
    and Body of the message will be ignored.
    Your use of Yahoo! Groups is subject to
    http://docs.yahoo.com/info/terms/
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    Hello,
    Don't forget that some I2C EEPROMs have page write buffer boundaries. For
    example the Microchip 24LC32A has a page write buffer of 32 bytes. If you
    start writing at address 16 then you can only write 16 bytes before the
    page write buffer rolls over. To use the whole buffer you have to start
    writing at 32 bytes boundaries (0, 32, 64, etc..).
    This caused me quite a bit of headache when I first tried using one. I
    skimmed over it when I read the spec sheet!
    Chuck Chargin Jr.
    >-- Jon Williams
    >-- Dallas Office
    Original Message
    >I use BS2p.
    >abuse@p....
    >from the same email address that you subscribed. Text in the Subject and
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    I'm impressed of the inbuilt functions in BS2p. I try to utilize
    them as often as possible.
    The data flash AT45DB041 from ATMEL, is a SPI memory holding 2048
    pages * 256 bytes (0.54 Meg) and also has two 264-bytes SRAM data
    buffers. I was hoping to try out this circuit in the future, but
    first I should understand the use of the regular SPI Eeprom. In fact
    I have not even checked the price or accessibility from ATMEL, but
    my regular IC-shop doesn't sell ATMEL. I know that Tracy Allen has
    written that he has used this memory.
    I was asking how to use the shiftout/shiftin to store and retrieve
    string to the Eeprom.
    This DEMO-code works, but is there a better way instead of clocking
    in the char one byte at the time. Then perhaps I don't have to send
    one char at the time to the LCD.
    CON and VAR from 8K Eeprom APP-kit
    EEwrite:
    low CS ' Activate the EEPROM.
    shiftout DATA_N,CLK,msbfirst,[noparse][[/noparse]WriteEE]' Send write opcode.
    Eeaddr=8191
    For Index= 0 to 13
    EEaddr=EEaddr+1
    Gosub Send_addr ' Send the address.
    Lookup index,[noparse][[/noparse]"This is a test"],Result
    shiftout DATA_N,CLK,msbfirst,[noparse][[/noparse]Result] ' Send the data.
    Next
    high CS ' Deactivate the EEPROM.
    return ' Return to program.
    EEread:
    shiftout DATA_N,CLK,msbfirst,[noparse][[/noparse]ReadEE] ' Send the read opcode.
    EEaddr=0
    For Index=0 to 13
    EEaddr=EEaddr+1
    shiftin DATA_N,CLK,msbpre,[noparse][[/noparse]INdata]' Get the data.
    Debug Indata
    LCDOUT 1,MoveCrsr+Index,[noparse][[/noparse]INdata]' LCD must then show one
    char at the time.
    Next
    --- In basicstamps@yahoogroups.com, "Chuck Chargin Jr."
    <cchargin@e...> wrote:
    > Hello,
    boundaries. For
    bytes. If you
    before the
    start
    one. I
    > Chuck Chargin Jr.
    memory,
    > >-- Jon Williams
    > >-- Dallas Office
    Original Message
    > >I use BS2p.
    Subject
    > >abuse@p...
    Subject and
    Using SHIFTOUT I'm afraid you will have to do it a byte at a time. Part
    of the reason for this is that SHIFTOUT allows you to shift other than
    8-bit values, so you cannot use "string" designations (slash parameter)
    in SHIFTOUT like you can in other routines (I2COUT, for example).
    -- Jon Williams
    -- Parallax
    Original Message
    Sent: Sunday, August 10, 2003 6:39 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Best way to store a string in a SPI Eeprom?
    EEwrite:
    Eeaddr=8191
    For Index= 0 to 13
    EEaddr=EEaddr+1
    Next
    EEread:
    EEaddr=0
    For Index=0 to 13
    EEaddr=EEaddr+1
    Debug Indata
    char at the time.
    Next
    > Hello,
    boundaries. For
    bytes. If you
    before the
    start
    one. I
    > Chuck Chargin Jr.
    memory,
    > >-- Jon Williams
    > >-- Dallas Office
    Original Message
    > >Is there a fast code of sending a whole string (not passing the block
    > >I use BS2p.
    Subject
    > >abuse@p...
    Subject and
    abuse@p....
    EEPROM self-increments its address within each block, so you don't
    necessarily have to send the address for each byte. However, like
    I2C, you have to respect the block boundaries, otherwise you will end
    up overwriting in circles back at the beginning of the same block.
    The block size is usually quite small, like 16 or 32 bytes. (The
    ATMEL dataflash blocks are 264 bytes).
    Say you want to send a word data, then use
    GOSUB send_addr
    shiftout dpin,cpin,msbfirst,[noparse][[/noparse]word_data\16] ' sixteen bits
    Strings? The idea is to send the address and initiate a new block
    only when the string crosses block boundaries. Remember that it
    takes a few milliseconds for eeprom to write data, so if you can
    write a whole block at once, you can save a lot of execution time.
    Suppose a string is stored (buffered) starting at address 0 in the
    SPRAM of the BS2p, and that the string is N bytes long, which may be
    more or less than the blocksize. The string needs to be moved to
    eeprom, starting at address held in ADDR0. Suppose the blocksize=32
    bytes.
    ' {$PBASIC 2.5}
    for i=0 to N-1 ' N bytes in string
    addr=addr0+i ' address of next byte in eeprom
    if addr // blocksize = 0 OR i=0 then gosub send_addr ' do this
    only to start a new block write.
    get i,char ' from SPRAM
    shiftout DATA_N,CLK,msbfirst,[noparse][[/noparse]char] ' Send the data, but don't
    close the write
    next
    high CS ' close the final write.
    end ' would normally update ADDR0=ADDR0+N
    send_addr: ' start new block
    high CS ' close last write
    ' should check the eeprom status byte here, to allow it to complete
    the write!!! or PAUSE 9
    low CS
    shiftout dta,clk,msbfirst,[noparse][[/noparse]WREN] ' write enable opcode.
    high CS ' register it.
    low CS ' Activate EEPROM.
    shiftout dta,clk,msbfirst,[noparse][[/noparse]WrEE] ' write opcode.
    high CS ' register it low CS
    ' send address
    shiftout dta,clk,msbfirst,[noparse][[/noparse]ADDR\16]
    return ' with address open for writing
    There may be better ways to code it, with an inner loop that does not
    test for the beginning of the block. This kind of routine also is
    good for erasing eeprom, say, because you can send cycles of 16 $FFFF
    to the whole memory array, and burn each block in multiples of 32
    bytes.
    -- Tracy
    >EEwrite:
    > Eeaddr=8191
    > For Index= 0 to 13
    > EEaddr=EEaddr+1
    > Next
    >EEread:
    > EEaddr=0
    > For Index=0 to 13
    > EEaddr=EEaddr+1
    > Debug Indata
    >char at the time.
    > Next
    >> Hello,
    >boundaries. For
    >bytes. If you
    >before the
    >start
    >one. I
    >> Chuck Chargin Jr.
    >memory,
    >> >-- Jon Williams
    >> >-- Dallas Office
    Original Message
    >> >I use BS2p.
    >Subject
    >> >abuse@p...
    >Subject and
    >Subject and Body of the message will be ignored.
    Thanks Tracy, your help is really appreciated.
    I just got hold of a free sample Atmel IC as well.
    Stein.
    end
    block.
    > GOSUB send_addr
    block
    be
    blocksize=32
    > bytes.
    > ' {$PBASIC 2.5}
    this
    don't
    > close the write
    > next
    complete
    > low CS
    > ' send address
    not
    $FFFF
    > bytes.
    > -- Tracy
    clocking
    send
    > >EEwrite:
    > > Eeaddr=8191
    > > For Index= 0 to 13
    > > EEaddr=EEaddr+1
    > > Next
    > >EEread:
    opcode.
    > > EEaddr=0
    > > For Index=0 to 13
    > > EEaddr=EEaddr+1
    > > Debug Indata
    > >char at the time.
    > > Next
    > >> Hello,
    > >boundaries. For
    > >bytes. If you
    > >before the
    to
    > >start
    > >one. I
    > >> Chuck Chargin Jr.
    > >memory,
    > >> >-- Jon Williams
    > >> >-- Dallas Office
    Original Message
    Eeprom?
    a
    > >> >I use BS2p.
    > >Subject
    to
    > >> >abuse@p...
    > >Subject and
