bs2-->rs232-->USB-->macintosh-->Java or C++
ArchiverArchiver Posts: 46,084
I think that my problem is of the most basic nature--software to
hardware-- but after searching for weeks for a definite answer, I am
almost sure it is hopeless.
Basically, I am trying to get numbers from a bs2 controlled sonar
circuit into a variable in either java or c++ in my macintosh
throught the usb port.
I believe I have solved the USB part of this, but now I do not know
how I will begin to go about getting the values into the software.
Perhaps someone here has done some similar work on the mac and can
help me a bit.
  • 5 Comments sorted by Date Added Votes
  • ArchiverArchiver Posts: 46,084
    edited May 2002 Vote Up0Vote Down
    Hi,
    This is a copy of an email I sent to someone else (or is it the same
    person??) :-)
    It relates to the FTDI USB chips/Modules...
    For the Mac, you install an Extension from ftdi which creates a "Virtual
    serial port".
    That means, that your existing programs that normally talk to the old Mac
    serial port will still believe they are talking to one, and the Extension
    will transfer any calls to the serial port to the FTDI chip instead.
    So, as far as writing software goes, you just carry one writing your
    programs, addressing the the serial port.
    I'm not sure about how to address a serial port in C++ for the Mac, but in
    RealBasic, it's something like:
    serial1.write "Hello!"
    As long as you have the extension installed, your program will work on a USB
    based Mac.
    Hope this helps,
    Cheers,
    Ben.
    http://www.lennard.net.nz/
    Ben Lennard, NCEE, Dip EE
    Web Hosting and Electronics R&D
    Club Coordinator, Victoria University of Wellington Hockey Club
    Hm: +64 4 972 7567
    Mb: +64 21 536 627
    87 Spencer Street
    Crofton Downs
    Wellington
    New Zealand
    "To the optimist, the glass is half full. To the pessimist, the glass is
    half empty. To the engineer, the glass is twice as big as it needs to be."
    No animals were harmed in the transmission of this email, although the
    Dog next door is living on borrowed time, let me tell you! Those of you
    with an overwhelming fear of the unknown will be gratified to learn that
    there is no hidden message revealed by reading this warning backwards.
    >From: "papercats2000" <olegna78@a...>
    >To: basicstamps@yahoogroups.com
    >Subject: [noparse][[/noparse]basicstamps] bs2-->rs232-->USB-->macintosh-->Java or C++
    >Date: Mon, 6 May 2002 6:46 PM
    > help me a bit.
    > Thanks
    > To UNSUBSCRIBE, just send mail to:
    > from the same email address that you subscribed. Text in the Subject and
    > Body of the message will be ignored.
    > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    Yes, I did send this to you personally as well. Sorry. I thought it would
    be good to put it on the board for all to see.
    Thanks again, and remember, the info you gave me is not on the internet at
    all!
    Hi,
    I don't know if this will help, I haven't used any of this, but from a
    distance it looks like you should check out:
    http://www.serialio.com/products/serialport/serialport.htm
    They have mac versions, old and new. This stuff should work with any
    aftermarket usb-> serial adapter. The way to connect the stamp to a serial port
    is I think identical to how you would do it for the pc, you just need the
    pinouts...
    Good Luck, and please, if you make it work, post what you can here. I probably
    need to solve a similar problem myself soon.
    Stan
    > help me a bit.
    > Thanks
    Thanks Stan. I saw that page during my week-long struggle, but I kept
    searching for things that looked cheaper and finally settled on ftdi usb
    chips and drivers.
    Again thanks. I CAN'T BELIEVE i GET HELP WITH SUCH A SPECIFIC PROBLEM OOPS
    SOrry for the all caps.
    ~Angelo
