Connector hole pattern — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2001-05-04 20:28 in General Discussion
Howdy Stampers,
I am looking for a male db9 connector or a
rj-14 connector or such that I can mount to
a PCB with straight connections without the
staggered hole pattern. Unless the board is
geared for it, the staggered hole pattern
does not work with the standard .100 (100 mil)
matrix hole spacing of the boards I have.
Does anyone know of a manufacturer that
accomodates a connector that will plug
directly into a solderless breadboard?
Bandit
If you understand, things are just as they are.
If you do not understand, things are just as they are.
  • ArchiverArchiver Posts: 46,084
    edited 2001-05-04 16:40
    Bandit,
    Our ASP-II brings the pins that are important for the Stamp into a straight
    format for a breadboard. In particular, it connects 2, 3, 4, 5, and shorts 6
    & 7.
    http://www.al-williams.com/awce/asp2.htm
    Meant for Stamp prototyping, but I use it to connect all sorts of serial
    stuff to a breadboard.
    Al Williams
    AWC
    Expand your Stamp I/O!
    http://www.al-williams.com/awce/pak3.htm
    Original Message
    > From: Sample Bandit [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=D0tOGP5xSDFOD2HkbslvnDjbQRzN7sCJPeAH-bZU6tS3onjAF6iLZQjiQUqTEFdiccwwXuXZheA]tesla@i...[/url
    > Sent: Friday, May 04, 2001 10:31 AM
    > To: basicstamps@yahoogroups.com
    > Subject: [noparse][[/noparse]basicstamps] Connector hole pattern
    > Howdy Stampers,
    > Thanks,
    > Bandit
    > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2001-05-04 16:53
    Al,
    Thanks for the quick reply and that looks like the
    puppy I had in mind but ouch! $15?
    I could buy 4 AVR's for that!
    Looks like I may be breaking out some pliers and bending
    the pins of a regular db9 to fit.
    Bandit
    At 10:40 AM 5/4/01 -0500, you wrote:
    >Bandit,
    >& 7.
    >Regards,
    >Al Williams
    >AWC
    Original Message
    >> From: Sample Bandit [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JddonlNUJV4BcCmntTAedw4_JQgdrHg1Jd4CJ1iaLfaTcysVwfgkUyfJfVCpm53KFGlBiPQ]tesla@i...[/url
    >> Howdy Stampers,
    >> Thanks,
    >> Bandit
    edited 2001-05-04 17:01
    Well, you get the lab manual with projects, a battery connector, and our
    nice support :-)
    Al Williams
    AWC
    * Floating point math for the Stamp, PIC, SX, or any microcontroller
    http://www.al-williams.com/awce/pak1.htm
    Original Message
    > From: Sample Bandit [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hPL8aiqjih6HrMwGgApsRwmDAXQE8EwD8sL-c_jotG-gUMGkaE4MeVCDavVYTLgYJla4b08]tesla@i...[/url
    > Sent: Friday, May 04, 2001 10:54 AM
    > Subject: RE: [noparse][[/noparse]basicstamps] Connector hole pattern
    > Al,
    > Bandit
    > >Bandit,
    > a straight
    > and shorts 6
    > >& 7.
    > >Regards,
    > >Al Williams
    > >AWC
    Original Message
    > >> Howdy Stampers,
    > >> Thanks,
    > >> Bandit
    edited 2001-05-04 18:10
    I used a dual-row 10-pin header and ribbon cable connector for my board --
    works like a charm. The other end of the ribbon cable has a DB9 connector.
    See a photo of my processor board at:
    http://robostuff.com/dprg/bill_boyer/cpu-1.htm
    Original Message
    edited 2001-05-04 18:28
    Rodent,
    ········Would youtell us where you got the connectors that you used on your processorboard for the motor, I/R and ultrasonic hook-ups?· Did they come asmatched sets - male and female?
    Tim
    At 12:10 PM 5/4/2001 -0500, you wrote:
    I used a dual-row 10-pin header andribbon cable connector for my board --
    works like a charm. The other end of the ribbon cable has a DB9connector.
    ·http://robostuff.com/dprg/bill_boyer/cpu-1.htm
    Original Message
    Your use of Yahoo! Groups is subject tohttp://docs.yahoo.com/info/terms/
    Timothy Medema
    CrystaLite, Inc.
    3307 Cedar St.··················(425) 745-6000·· 800-666-6065
    Everett, WA 98201···············Fax: (425) 257-0232
    www.crystaliteinc.com···········timm@crystaliteinc.com
    The information transmitted is intended only for the person or entity to whom it is addressed and may contain confidential and/or privileged material.· Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited.· If you received this in error, please contact the sender and delete the material from any computer.
    edited 2001-05-04 19:44
    Available from Mouser. You buy the header, connector shell and contacts
    separate. I ordered 10 of each header and shell, and 150 of the contacts I
    think it works out to about 50 cents per connector.
    Headers (the part with the pins that goes on the board)
    4-pin header 538-22-23-2041
    3-pin header 583-22-23-2031
    Connector Housing (the part that plugs into the header)
    4-pin 538-22-01-3047
    3-pin 538-22-01-3037
    Contacts (the part the wire is soldered to that fits in the shell)
    538-08-50-0114
    Original Message
    > Would you tell us where you got the connectors that you used on
    > your processor board for the motor, I/R and ultrasonic hook-ups? Did they
    > come as matched sets - male and female?
    Rodent,
    Thank you much,
    Tim
    At 01:44 PM 5/4/2001 -0500, you wrote:
    Available from Mouser. You buy theheader, connector shell and contacts
    separate. I ordered 10 of each header and shell, and 150 of the contactsI
    ·538-08-50-0114
    Original Message
    >········· Would you tellus where you got the connectors that you used on
    > your processor board for the motor, I/R and ultrasonichook-ups?· Did they
    Timothy Medema
    CrystaLite, Inc.
