Convert 25Ch Cordless Ph. To 6M Amateur (Motorola SPI/PLL Help!) — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2000-04-07 07:56 in General Discussion
Hi all, I have a little amateur radio project. Conversion of
25-channel cordless phones to the 6 meter band. After opening
about 20 phones here is what was found: (Base unit modification.)
- Most use the Motorola MC145162 dual 60 MHz PLL. (SMT or DIP)
- Most use a Motorola LSCxxxxxx to control the whole phone.
The idea is to remove the phone's CPU (Motorola LSCx) and replace
it with connection to a BS2, using the SHIFTOUT command to load
new frequency data into the PLL. The phone can be connected to an
amplifier and there you go, a 2-way radio. After about 20 hours
of work the BS2 still will not talk to the PLL using SPI. This PLL
outputs a High signal when it is in the UNlocked state. So far
this is what it always sits at. Most of the required information
for setting up the PLL is visibile on the board: Local OSC freq etc.
- Older phones are using a different PLL: MC145167 (serial input)
which is a pre-programmed version containing 10-channels and an
input bit for handset or base frequency selection... this
chip is easy to talk to with SHIFTOUT 1,1,[noparse][[/noparse]5] and the phone
is transmitting on channel 5. This means you are stuck on
cordless phone frequencies not amateur radio. Not very interesting.
But it worked on the first try.
If anyone has information/experience with SPI or these PLL's
please send an email! Thank-you!
William Franzin, VE4VR
wfranzin@h... or
william@f...
BS2-Repeater Controller at: http://www.lwa.mb.ca/ve4gbu/
  • ArchiverArchiver Posts: 46,084
    At 06:50 AM 4/7/00 -0000, wfranzin@h... promulgated:
    William -
    Please be aware that the PBASIC Shiftout command and the inherent structure
    of the bit-serial system implemented on the Parallax STAMP proceesor WILL NOT
    emulate all of the possible SPI modes. Specifically, any which rely on the
    polarity of the clock line, and or the width or duration of the clock pulse.
    See Motorola Microprocessor SPI specifications for details.
    The details of what the Stamp CAN produce may be found in the Parallax PBASIC
    Manual for the Stamp II. See specifically "A single Shiftout instruction
    causes
    the following sequence of events:" on Page 335, along with the explicit
    timing
    diagram I-26 (same page).
    Please contact me offlist at: bvbates@i... for any additional
    information
    Hope that helps
    Bruce
    >wfranzin@h... or
    >william@f...
