Level Detector — Parallax Forums
Level Detector
ArchiverArchiver Posts: 46,084
edited 2000-04-06 22:07 in General Discussion
Looking for ideas/circuits to accept a "line level" audio (analog)
input and generate a digital (zero or five volt) output. The idea is
for my Stamp to see a "1" if a (selectable?) level of audio signal is
present, or a "0" if the line is momentarily silent. Something like
the notion of an audio "squelch" control signal.
Any suggestions?
Steve
  • ArchiverArchiver Posts: 46,084
    edited 2000-04-06 18:47
    Steve:
    I assume that line level means ~100-200 mv rms audio. How about using an
    opamp precision rectifier fed into a comparator? The parts for this are
    cheap.
    Ray McArthur
    Original Message
    To: <basicstamps@egroups.com>
    Sent: Thursday, April 06, 2000 1:31 PM
    Subject: [noparse][[/noparse]basicstamps] Level Detector
    > Any suggestions?
    > Thanks,
    > Steve
    One reasonable way to do this is with an open-collector dual comparator
    like the LM393. The first comparator has its '+' input tied to a reference
    voltage perhaps 50~100mV above ground. The other input sees audio. Its
    output sucks down the voltage on a capacitor every time the input goes
    above threshold, while a pullup resistor charges the cap if there's no
    audio. The second comparator gives you a decisive 'digital' output. It
    should be set up with a little positive feedback (hysteresis) to prevent
    chattering around the decision point.
    Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
    Manufacturer of the famous BOB-II Serial Video Text Display Module!
