transistor switch — Parallax Forums
transistor switch
ArchiverArchiver Posts: 46,084
edited 2000-04-06 18:38 in General Discussion
I need to actuate a 12v solenoid and control it with the 5v output of
the Stamp.
I have a TIP31c npn transistor and the resistance of the solenoid is
90 ohms.
How do I bias this transistor to act like a switch, switching 12volts
to actuate the solenoid?
Ed Lentz
Elentz@e...
  • ArchiverArchiver Posts: 46,084
    edited 2000-04-05 02:40
    Ed:
    Your 12V solenoid will draw~ 12V/90 ohms, or 133 ma. The TIP31C data sheet
    indicates that this transistor will saturate nicely at this collector
    current with ~5 ma. base current. If we allow 0.7V for Vbe, You need a base
    resistor of (5-0.7)/.005=860 ohms. The standard value of 820 ohms would do
    nicely, 1/8 watt or more.
    1) ground the emitter.
    2) connect the solenoid from collector to +12V.
    3) connect the 820 ohm resistor from the stamp pin to base.
    4) connect a diode across the solenoid to protect against the inductive
    turn-off spike. The diode should be rated for at least 133 ma and at least
    12V. The diode should "point" toward +12V.
    Ray McArthur.
    Original Message
    To: <basicstamps@egroups.com>
    Sent: Tuesday, April 04, 2000 8:42 PM
    Subject: [noparse][[/noparse]basicstamps] transistor switch
    > the Stamp.
    > 90 ohms.
    > Thanks
    > Ed Lentz
    > Elentz@e...
    edited 2000-04-05 02:48
    Go to:
    http://206.19.206.56/parallel.htm
    Look all the way to the bottom and there is a description and picture of
    what you want.
    Tim
    [noparse][[/noparse]Denver, CO]
    Original Message
    > From: elentz@e... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ARmY9P42YUUZDn2B-0Pya73r4aHVbYLMUO43qI_NSiLv4oTZNN-e-U7Gum_4VZWfoPR9HrSyOa7MD5b2EuM8zw]elentz@e...[/url
    > Sent: Tuesday, April 04, 2000 6:43 PM
    > To: basicstamps@egroups.com
    > the Stamp.
    > 90 ohms.
    > Thanks
    > Ed Lentz
    > Elentz@e...
    edited 2000-04-05 13:54
    One way is to just saturate the transistor like a switch
    another is to use a power mosfet
    if all else fails get a $2- $3 radio shack relay that has a coil than
    directly runs off low power logic signals
    richard
    Original Message
    Sent: Tuesday, April 04, 2000 7:42 PM
    > the Stamp.
    > 90 ohms.
    > Thanks
    > Ed Lentz
    > Elentz@e...
    edited 2000-04-05 14:02
    good answer,
    I drew out the circuit because I can remember circuits a whole lot longer
    than I can words
    even though I didn't ask the question - thanks for taking the time to answer
    it
    richard
    Original Message
    Sent: Tuesday, April 04, 2000 8:40 PM
    Subject: Re: [noparse][[/noparse]basicstamps] transistor switch
    > Ed:
    sheet
    base
    do
    least
    > Ray McArthur.
    Original Message
    > From: <elentz@e...>
    > > the Stamp.
    > > 90 ohms.
    > > Thanks
    > > Ed Lentz
    > > Elentz@e...
    edited 2000-04-05 15:26
    Chuck Britton wrote:
    > At 10:51 AM -0400 4/5/00, Bruce Bates wrote:
    > >At 07:54 AM 4/5/00 -0500, dakota promulgated:
    > >Just to add another option -
    > >a solid state relay
    > gotta be careful here.
    > MOST solid state relays are designed for AC and NEED AC in order to 'turn
    off'.
    > Most of them will turn ON a DC current but will LATCH in the on state
    > regardless of your input signal. (IIRC)
    > \ / \ / \ N / \ C / \ S / \ S / \ M / \ / \ /
    > Chuck Britton Education is what is left when
    > britton@a... you have forgotten everything
    > North Carolina School of Science & Math you learned in school.
    > (919) 286-3366 x224 Albert Einstein, 1936
    Just my .02 here.
    I had a similar question a while back. Someone on the list recommended solid
    state relays. I purchased four (AQZ102) These are dc relays. They have been
    cycled repeatedly for hours without any failure (I've been doing some long term
    usability testing to see if they would hold up).
    I'll have to look up where I got them and who made them..But would gladly do so
    if
    you want the information.
    Rus
    Rus Hardy
    "Lucky Devil"
    Keeper of the Bucky-n-Thrifty Flame
    http://www.bluedestiny.com/Anatomical/Index.shtml
    "my mind wanders....I'm just along for the ride"
    edited 2000-04-05 15:51
    a solid state relay
    >richard
    Original Message
    >From: <elentz@e...>
    >> the Stamp.
    >> 90 ohms.
    >> Thanks
    >> Ed Lentz
    >> Elentz@e...
    edited 2000-04-05 16:14
    >a solid state relay
    MOST solid state relays are designed for AC and NEED AC in order to 'turn off'.
    edited 2000-04-05 16:34
    At 11:14 AM 4/5/00 -0400, Chuck Britton promulgated:
    >>a solid state relay
    off'.
    Depends upon the unit you purchase.
    See above
    edited 2000-04-05 16:37
    At 10:26 AM 4/5/00 -0400, Rus Hardy promulgated:
    >> >a solid state relay
    'turn off'.
    left when
    everything
    1936
    >Just my .02 here.
    solid
    been
    term
    do so if
    Thanks for the confirmation Rus - I would had to dig my dox out.
    Bruce
    >Rus
    >Rus Hardy
    >"Lucky Devil"
    edited 2000-04-05 23:39
    How would you drive the mosfet? What kind of driver if you wanted to run
    about 5 large output mosfets with ttl level gates? (IRL3102 by IRF)How do
    you protect the micro? Considering a gate "on" voltage of 2.7vdc and a max
    gate voltage of 10vdc, a source voltage of 12vdc, 20 amps and more at
    startup, the motor is brushless dc and I'm told there will be a voltage
    spike when it shuts down. What if I wanted to pulse the gate current to
    achieve speed control. How would I build the h-bridge to change motor
    direction and do braking? Is there a way to make it rs-232 controlled?
    Bill
    > richard
    Original Message
    > From: <elentz@e...>
    > > the Stamp.
    > > 90 ohms.
    > > Thanks
    > > Ed Lentz
    > > Elentz@e...
    Are there examples of the use of mosfets with the stamp and large dc motors on
    the internet?
    > Bill
    > > richard
    Original Message
    > > From: <elentz@e...>
    > > > the Stamp.
    > > > 90 ohms.
    > > > Thanks
    > > > Ed Lentz
    > > > Elentz@e...
