Stamp to PIC conversion — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2000-04-06 18:04 in General Discussion
Are then any companies that will take a PBASIC program and put it onto a
PIC?
Jim
  • ArchiverArchiver Posts: 46,084
    edited 2000-04-06 15:22
    At 02:38 PM 4/6/00 +0100, Jim Wilkins promulgated:
    >PIC?
    Commercial use or non-commercial use ?
    If the latter, I suspect one of us on the Stamp List might be able to
    accomodate
    you. I would happily generate the code for you, but my hardware setup is in
    a bit
    of disarray at the moment, so I'd beg off on "cutting" the PIC. You would also
    have to check into which PIC you might want to use; although there are
    certain
    defacto units which are often used.
    If the former, I'd suggest you purchase the software Micro Engineering Labs(*)
    [noparse][[/noparse]MEL] - either their PBASIC or PBASIC Pro translators. They will take Stamp
    PBASIC Input Statements (PBASIC = Stamp I, PBASIC Pro = Stamp II) and produce
    assembler macros, which then can be assembled with provided assemblers, for
    later loading and embedding ("cutting" above) into a PIC.
    (*) Other offerings do exist, but this is a commercially supported product
    One also needs a PIC programmer to accompish this task for Stamp I or Stamp
    II
    syntax, and the MEL "system". For Stamp I syntax, without outside support,
    other specific case options do exist.
    The MEL Software can be purchased directly from them, or from some of the
    other
    vendors who support the Stamp/PIC community. I purchased mine from Chuck
    Hellebuyck
    at www.elproducts.com since he had a package deal at the time. You'd have
    to check
    his website for details.
    Hope that helps
    Bruce
    >Jim
    edited 2000-04-06 15:55
    >PIC?
    accomodate
    a bit
    certain
    II
    other
    Hellebuyck
    to check
    **IMPORTANT ADDITION
    Lest I not forget, Micro Engineering Products are also available in Canada
    http://www.HVWTech.com
    (that should keep NAFTA off my back <smile> Hi Mark !).
    Hope that helps
    Bruce
    >Jim
    I would assume there are several. Most consultants would do this but it
    will not necessarily be cheap. If you are interested in a quote contact me
    off list. You can also get a basic compiler and compile your code and load
    it into a PIC. There are several ways to go.
    Larry
    >PIC?
    >Jim
    Larry G. Nelson Sr.
    mailto:L.Nelson@i...
    http://www.ultranet.com/~nr
