Need help - dodgy error!! — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2000-04-05 16:08 in General Discussion
While doing the datalogging section of PBASIC we load in a program
using the template.bas file.
We get an error:
Error: can't malloc any more memory (more_nodes)!
What does this mean?? and how do i get around it??
Here is the code we use:
pause 5
serout S_OUT,T2400,(254,1)
pause 30
main:
low ADC_MPX
gosub adcread
serout 7,t2400,(254,128)
serout 7,t2400,("Sensor 1= ",#data," ")
high ADC_MPX
gosub adcread
serout 7,t2400,(254,192)
serout 7,t2400,("Sensor 2= ",#data," ")
pause 1000
goto main
If you require the other code for the sub-procs etc request and i
will deliver.
Thanks - any help appreciated.
  • ArchiverArchiver Posts: 46,084
    At 02:04 PM 4/5/00 -0000, Mark Prentice promulgated:
    The above filename xxxxx.bas may well be invoking a Windows based Basic
    Compiler,
    in lieu of the PBASIC Interpereter. The correct syntax for the PBASIC
    Interpreter
    is:
    STAMPn[noparse][[/noparse].EXE] /m fn.ft DOS Version
    fn = file name,
    ft = filetype
    where: n = 1 or 2 (Version: Stamp I or Stamp II)
    m = 1 or 2 represents the serial COMM port to
    which the Stamp is physically attached
    STAMP2SX[noparse][[/noparse].EXE] (as above) Stamp II-SX Version
    STAMPW[noparse][[/noparse].EXE] (usually run alone w/o parameters) Windows 9x/NT Version
    >We get an error:
    Alternatively this could indicate insufficient memory or file handles in a
    Windows based program.
    What is the command line being executed, and with which operating system ?
    >pause 5
    >pause 30
    >main:
    >low ADC_MPX
    >gosub adcread
    >high ADC_MPX
    >gosub adcread
    >pause 1000
    >goto main
    >will deliver.
    It should have nothing to do with the PBASIC code (unless it's an internal
    PBASIC Interpreter error - unreported to date, as far as I am aware).
    More info <smile> !
    Bruce
