Multimeter — Parallax Forums
Multimeter
ArchiverArchiver Posts: 46,084
edited 2000-04-02 17:45 in General Discussion
How do multimeters measure resistance? and is there any way to do this with a
stamp
  • ArchiverArchiver Posts: 46,084
    Multimeters typically supply a small voltage through the probes and measure
    the current. That's why in the old days you had to "zero" your ohm meter, to
    account for variations in the batteries, etc.
    The easiest way to measure resistance with the Stamp is to use the POT
    (Stamp I) or RCTime (Stamp II) commands. These are made to measure the time
    it takes a capacitor to charge or discharge through a resistance. Therefore
    you can use it to determine R or C if you know the other one. The idea is
    that you discharge the capacitor and then wait for it to charge up to the
    Stamp's input threshold voltage. When the voltage on the capacitor flips
    from a logic 0 to a logic 1, the Stamp reports the time. You can do the same
    thing if you reverse the words charge and discharge along with 0 and 1 in
    the above sentence.
    Read the Stamp manual under RCTime. You'll also find a capacitance meter
    project in my book Microcontroller Projects with Basic Stamps that could
    have been an ohmmeter very easily.
    Al Williams
    AWC
    * Measure 8 pulse inputs with the PAK-VII -
    www.al-williams.com/awce/pak7.htm
    Original Message
    > From: BJTkid3@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZBRPNWYU1Luyvb0y0UiyO-B9sLP5hbSWIHIqW_q1exxmHSEoNwAELtLQRQprUWoWfDUS-WIkB3mFtg]BJTkid3@a...[/url
    > Sent: Sunday, April 02, 2000 11:36 AM
    > To: basicstamps@egroups.com
    > Subject: [noparse][[/noparse]basicstamps] Multimeter
    > this with a
    > stamp
    > eGroups.com home: http://www.egroups.com/group/basicstamps
    > http://www.egroups.com - Simplifying group communications
