Robot Ideas and examples — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2000-03-25 19:16 in General Discussion
Hello everyone: I think it would be interesting to read about robots built
from stamps.
Would people care to write some letters to the list about robots they have made?
Just a thought,seemed like an interesting topic to have going for a little
while.
I myself am just getting started in robotics
Sincerely
Kerry
Admin@M...
WWW server hosting
[url=Http://mntnweb.com]Http://mntnweb.com[/url]
Binghamton online Webcam [url=Http://MntnWeb.Com/bing.htm]Http://MntnWeb.Com/bing.htm[/url]
CHRISTMAS Web Page [url=Http://mntnweb.com/xmas.htm]Http://mntnweb.com/xmas.htm[/url]
  • ArchiverArchiver Posts: 46,084
    edited 2000-03-24 16:48
    Kerry,
    > from stamps.
    made?
    > while.
    Most of my bots have been stamp based. You can check my site:
    http://www.verinet.com/~dlc/botlinks.htm for some details on them. Also,
    we have a club on Yahoo, The Robotics Club of Yahoo, TRCY that has designed
    our own Stamp II based robot from OEM Stamp chips. Its called TRaCY and
    has a PC board with I/O ports and a built-in IRPD circuit. The kit comes
    with program examples, full construction details, with illustrative pictures
    etc. Its a complete robot you have to build from the ground up. Best of
    all, its under $100, all parts included. We did it so that club members
    could have a low-cost robot that was the same for everyone for club challenges
    and future gatherings (we hope!). Go to http://clubs.yahoo.com and look
    for TRCY or The Robotics Club. There are pointers to the club website from
    there too.
    have fun,
    DLC
    * Dennis Clark Aristocrat at heart dlc@v... www.verinet.com/~dlc *
    * Be well, do good work, and stay in touch -- Garrison Keillor *
    edited 2000-03-24 20:55
    Umm.... my bot is a uses two modified 3003 servos with a LEGO tank tread for
    propulsion. I uses one BS2 as it's brain. I've breadboarded a Maxim 8
    channel ADC, that I hope to get finalized soon. I'm going to use it for 2-4
    light sensors. I've also got a BOBIRD (Dan Cragan) design IRPD, along with 4
    IR detectors that I can use with my 4 IRLEDs and a 555 for added detection.
    I recently order a Sharp 12 DIRRS sensor for range finding, along with a
    servo to rotate it. I also ordered a TI 1amp h-bridge to drive motors (I
    don't know what for [noparse]:)[/noparse]. I've also hacked a PIR sensor from Wal-Mart I hope
    to use for crude people sensing. I've got the whole thing hooked up to 4
    1600mah NiCd batteries, or for lighter weight, I hook up 4 900 mah NiCds.
    The chassis is made from LEGOs. I have a plethora of them [noparse]:)[/noparse]
    -William
    Original Message
    To: <basicstamps@egroups.com>
    Sent: Friday, March 24, 2000 11:16 AM
    Subject: [noparse][[/noparse]basicstamps] Robot Ideas and examples
    > from stamps.
    made?
    little
    > while.
    > Sincerely
    > Kerry
    > Admin@M...
    > WWW server hosting
    > eGroups.com Home: http://www.egroups.com/group/basicstamps/
    > http://www.egroups.com - Simplifying group communications
    edited 2000-03-25 15:50
    Bill,
    I know that there is a company that builds motor controllers that are RS232
    controllable. However, they come motor, controller and all and are NOT cheap.
    Since you are on a stamp list... You can use RS232 to talk to a Stamp,
    use the
    stamp to generate PWM to control an RC car ESC that can handle 12V input and
    drive the motor that way.
    DLC
    Bill Katakis wrote:
    > Hi,
    > I want to run a 12v dc motor (10-20amps) from a car battery using rs232 , does
    > someone make a motor controller(forward, reverse, brake) that is controlled by
    > rs232? Is there a plan for a freebie out there somewhere?
    > Bill
    > > -William
    Original Message
    > > From: Kerry Barlow <admin@m...>
    > > > from stamps.
    > > made?
    > > little
    > > > while.
    > > > Sincerely
    > > > Kerry
    > > > Admin@M...
    > > > WWW server hosting
    > > -- 20 megs of disk space in your group's Document Vault
    > > -- http://www.egroups.com/docvault/basicstamps/?m=1
    Dennis Clark http://www.verinet.com/~dlc
    dlc@v...
    edited 2000-03-25 16:14
    Bill,
    Use one of the serial servo controller options. You can then use 1
    line to
    handle several of that style PWM. You're going to need a lot more than one
    stamp for 100 I/O!
    DLC
    Bill Katakis wrote:
    > PWM sounds good, but I need a bunch of the other stamp lines for other tasks.
    > Nearly 100 I/O.
    > Bill
    > Dennis Clark wrote:
    > > Bill,
    RS232
    cheap.
    > > use the
    > > DLC
    > > Bill Katakis wrote:
    > > > Hi,
    does
    controlled by
    > > > Bill
    for
    2-4
    with 4
    detection.
    hope
    NiCds.
    > > > > -William
    Original Message
    built
    > > > > > from stamps.
    have
    > > > > made?
    > > > > little
    > > > > > while.
    > > > > > Sincerely
    > > > > > Kerry
    > > > > > Admin@M...
    > > > > > WWW server hosting
    > > dlc@v...
    > > eGroups.com home: http://www.egroups.com/group/basicstamps
    dlc@v...
    edited 2000-03-25 16:37
    Bill,
    You know, I think they do carry the Scott Edwards SSCII. Also, to
    answer your other
    question - those will ONLY control hobby servos or devices that use the
    same signals.
    For instance RC car Electronic Speed Controls use the same signal as
    servos to control
    small voltage motors at very high currents (steady current of 20-50 Amps
    and startup
    draw as high as 200Amps). They are generally 4.8 to 8.4V with some
    controllers able to
    deal with up to 12V motors.
    have fun,
    DLC
    Bill Katakis wrote:
    > Dennis,
    > Where are the serial servo controllers, does Parallax carry them? About the
    100 I/O, I
    > was thinking of a shift register of some kind.
    > Bill
    > Dennis Clark wrote:
    > > Bill,
    > > line to
    > > stamp for 100 I/O!
    > > DLC
    tasks.
    > > > Nearly 100 I/O.
    > > > Bill
    > > > Dennis Clark wrote:
    > > > > Bill,
    RS232
    cheap.
    > > > > use the
    and
    > > > > DLC
    > > > > Bill Katakis wrote:
    > > > > > Hi,
    rs232 , does
    controlled by
    > > > > > Bill
    tread for
    8
    for 2-4
    along with 4
    detection.
    with a
    motors (I
    I hope
    to 4
    NiCds.
    > > > > > > -William
    Original Message
    robots built
    > > > > > > > from stamps.
    they have
    > > > > > > made?
    a
    > > > > > > little
    > > > > > > > while.
    > > > > > > > Sincerely
    > > > > > > > Kerry
    > > > > > > > Admin@M...
    > > > > > > > WWW server hosting
    > > > > dlc@v...
    > > dlc@v...
    > -- Check out your group's private Chat room
    > -- http://www.egroups.com/ChatPage?listName=basicstamps&m=1
    dlc@v...
    edited 2000-03-25 17:15
    100 I/O?? What about a HC12? I think some configurations have about 90 I/O.
    Go to http://robot-central.webjump.com/microcontroller.htm, and check under
    HC12.
    -William
    Original Message
    Sent: Saturday, March 25, 2000 1:52 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Robot Ideas and examples
    tasks.
    > Nearly 100 I/O.
    > Bill
    > Dennis Clark wrote:
    > > Bill,
    RS232
    cheap.
    > > use the
    and
    > > DLC
    > > Bill Katakis wrote:
    > > > Hi,
    rs232 , does
    controlled by
    > > > Bill
    tread for
    8
    for 2-4
    along with 4
    detection.
    with a
    motors (I
    I hope
    to 4
    NiCds.
    > > > > -William
    Original Message
    robots built
    > > > > > from stamps.
    they have
    > > > > made?
    a
    > > > > little
    > > > > > while.
    > > > > > Sincerely
    > > > > > Kerry
    > > > > > Admin@M...
    > > > > > WWW server hosting
    > > dlc@v...
    edited 2000-03-25 18:34
    Hi,
    Bill
    > -William
    Original Message
    > > from stamps.
    > made?
    > little
    > > while.
    > > Sincerely
    > > Kerry
    > > Admin@M...
    > > WWW server hosting
    edited 2000-03-25 18:52
    Nearly 100 I/O.
    Bill
    Dennis Clark wrote:
    > Bill,
    > use the
    > DLC
    > Bill Katakis wrote:
    > > Hi,
    does
    by
    > > Bill
    for
    2-4
    4
    detection.
    > > > -William
    Original Message
    built
    > > > > from stamps.
    have
    > > > made?
    > > > little
    > > > > while.
    > > > > Sincerely
    > > > > Kerry
    > > > > Admin@M...
    > > > > WWW server hosting
    > dlc@v...
    edited 2000-03-25 19:14
    Dennis,
    Where are the serial servo controllers, does Parallax carry them? About the 100
    I/O, I
    Bill
    Dennis Clark wrote:
    > Bill,
    > line to
    > stamp for 100 I/O!
    > DLC
    tasks.
    > > Nearly 100 I/O.
    > > Bill
    > > Dennis Clark wrote:
    > > > Bill,
    RS232
    cheap.
    > > > use the
    and
    > > > DLC
    > > > Bill Katakis wrote:
    > > > > Hi,
    , does
    controlled by
    > > > > Bill
    tread for
    for 2-4
    with 4
    detection.
    a
    (I
    hope
    4
    NiCds.
    > > > > > -William
    Original Message
    built
    > > > > > > from stamps.
    they have
    > > > > > made?
    > > > > > little
    > > > > > > while.
    > > > > > > Sincerely
    > > > > > > Kerry
    > > > > > > Admin@M...
    > > > > > > WWW server hosting
    > > > dlc@v...
    > dlc@v...
    Dennis,
    Does the controller care if the motor is not a servo motor??
    Bill
    Bill Katakis wrote:
    Dennis,
    Where are the serial servo controllers, does Parallax carry them?·About the 100 I/O, I
    Bill
    Dennis Clark wrote:
    > Bill,
    >·· Use one of the serial servo controller options.·You can then use 1
    > line to
    > handle several of that style PWM.· You're going to need a lotmore than one
    > stamp for 100 I/O!
    > DLC
    > Bill Katakis wrote:
    > > PWM sounds good,· but I need a bunch of the other stamp linesfor other tasks.
    > > Nearly 100 I/O.
    > > Bill
    > > Dennis Clark wrote:
    > > > Bill,
    > > >·· I know that there is a company that builds motorcontrollers that are RS232
    > > > controllable.· However, they come motor, controller andall and are NOT cheap.
    > > > Since you are on a stamp list...· You can use RS232 to talkto a Stamp,
    > > > use the
    > > > stamp to generate PWM to control an RC car ESC that can handle12V input and
    > > > DLC
    > > > Bill Katakis wrote:
    > > > > Hi,
    > > > > I want to run a 12v dc motor (10-20amps) from a car batteryusing rs232 , does
    > > > > someone make a motor controller(forward, reverse, brake) thatis controlled by
    > > > > rs232?· Is there a plan for a freebie out there somewhere?
    > > > > Bill
    > > > > William Cox wrote:
    > > > > > Umm.... my bot is a uses two modified 3003 servos with aLEGO tank tread for
    > > > > > propulsion. I uses one BS2 as it's brain. I've breadboardeda Maxim 8
    > > > > > channel ADC, that I hope to get finalized soon. I'm goingto use it for 2-4
    > > > > > light sensors. I've also got a BOBIRD (Dan Cragan) designIRPD, along with 4
    > > > > > IR detectors that I can use with my 4 IRLEDs and a 555 foradded detection.
    > > > > > I recently order a Sharp 12 DIRRS sensor for range finding,along with a
    > > > > > servo to rotate it. I also ordered a TI 1amp h-bridge todrive motors (I
    > > > > > don't know what for [noparse]:)[/noparse]. I've also hacked a PIR sensor fromWal-Mart I hope
    > > > > > to use for crude people sensing. I've got the whole thinghooked up to 4
    > > > > > 1600mah NiCd batteries, or for lighter weight, I hook up4 900 mah NiCds.
    > > > > > The chassis is made from LEGOs. I have a plethora of them[noparse]:)[/noparse]
    > > > > > -William
    Original Message
    > > > > > From: Kerry Barlow <admin@mntnweb.com>
    > > > > > > Hello everyone: I think it would be interesting to readabout robots built
    > > > > > > from stamps.
    > > > > > > Would people care to write some letters to the list aboutrobots they have
    > > > > > made?
    > > > > > >· Just a thought,seemed like an interesting topic tohave going for a
    > > > > > little
    > > > > > > while.
    > > > > > >· I myself am just getting started in robotics
    > > > > > > Sincerely
    > > > > > > Kerry
    > > > > > > Admin@MntnWeb.Com
    > > > > > > WWW server hosting
    > > > > > > Binghamton online Webcam·· [url=Http://MntnWeb.Com/bing.htm]Http://MntnWeb.Com/bing.htm[/url]
    > > > > > > http://www.egroups.com- Simplifying group communications
    > > > Dennis Clark·· http://www.verinet.com/~dlc
    > > > dlc@verinet.com
    > > > http://www.egroups.com -Simplifying group communications
    > > http://www.egroups.com - Simplifyinggroup communications
    > dlc@verinet.com
