New ActiveX control — Parallax Forums
New ActiveX control
ArchiverArchiver Posts: 46,084
edited 2000-03-25 15:07 in General Discussion
Hello Stampers,
We just finished a new ActiveX control that lets you build your own
custom RS-232 Data-Logging Terminal. It also comes as a complete
install ready to run if you're not into programming.
It was designed specifically for the BASIC Stamp, but can be used with
any microcontroller capable of sending asynchronous serial data to the
PC.
It will capture & display serial data sent from the BASIC Stamp, and log
data with a Date & Time stamp when the log-file is opened.
You can see it at: http://www.rentron.com/ActiveX.htm
Happy Stamping....8]
Bruce Reynolds
Reynolds Electronics
webmaster@r...
  • ArchiverArchiver Posts: 46,084
    edited 2000-03-21 09:48
    Link is FORBIDDEN
    Original Message
    To: basicstamps@egroups.com <basicstamps@egroups.com>
    Date: Friday, March 17, 2000 1:43 AM
    Subject: [noparse][[/noparse]basicstamps] New ActiveX control
    >Hello Stampers,
    >PC.
    >Regards,
    >Bruce Reynolds
    >webmaster@r...
    >-- Check out your group's private Chat room
    >-- http://www.egroups.com/ChatPage?listName=basicstamps&m=1
    The link works fine. Occasionally any link can produce an error
    message depending on the browser you're using, and server
    activity at the time you visit.
    --Bruce
    Original Message
    To: <basicstamps@egroups.com>
    Sent: Tuesday, March 21, 2000 2:48 AM
    Subject: [noparse][[/noparse]basicstamps] Re: New ActiveX control
    > Link is FORBIDDEN
    Original Message
    > From: Bruce <breyno2@r...>
    > >Hello Stampers,
    > >PC.
    > >Regards,
    > >Bruce Reynolds
    > >webmaster@r...
    > eGroups.com Home: http://www.egroups.com/group/basicstamps/
    > http://www.egroups.com - Simplifying group communications
