Hey, broken stamp II...HELP!!! — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2000-03-24 04:30 in General Discussion
Hello, my name is Matt (New), and I am having a problem with my basic stamp II...it just isn't getting the data from the computer.· I don't know if the chip, the board or the serial cable is fauly or brocken...does anyone have any good ideas, before i have to go spend $50 on another stamp?· I would really appreciate the help, thanx...
  • ArchiverArchiver Posts: 46,084
    edited 2000-03-20 12:31
    You wouldn't happen to be using a laptop would you? Can you give us any more
    info?
    -William
    Original Message
    To: <basicstamps@egroups.com>
    Sent: Monday, March 20, 2000 2:34 AM
    Subject: [noparse][[/noparse]basicstamps] Hey, broken stamp II...HELP!!!
    II...it just isn't getting the data from the computer. I don't know if the
    any good ideas, before i have to go spend $50 on another stamp? I would
    -- 20 megs of disk space in your group's Document Vault
    -- http://www.egroups.com/docvault/basicstamps/?m=1
    edited 2000-03-20 15:57
    Hi Matt,
    First of all what is the program saying that the "StampII found but not
    working. Check power sulply"? If so you most likly got a bad stamp and in
    that case call Pharallax, they make you do some test on it (well I had to
    any way) and if the think the stamp is bad they will replace it free of
    charge. I have had a problem like this before and Pharallax was very
    helpful, I wasn't on this list then.
    Hope this helps at least a little bit. There is not much you can do if it's
    a bad stamp.
    Chris Shuster
    http://www.uhpage.com/cpuman
    >From: "Matt" <vid6@h...>
    >Reply-To: basicstamps@egroups.com
    >Date: Sun, 19 Mar 2000 23:34:09 -0800
    ______________________________________________________
    edited 2000-03-20 16:04
    Matt,
    Can you turn off the HTML in your email? I'll make your messages about
    1/3 as long... Just a suggestion.
    > Hello, my name is Matt (New), and I am having a problem with my basic stamp=
    > II...it just isn't getting the data from the computer. I don't know if th=
    > e chip, the board or the serial cable is fauly or brocken...does anyone hav=
    > e any good ideas, before i have to go spend $50 on another stamp? I would =
    You didn't say if you ever got it to work. Did it just stop working or
    did you just get the setup and can't get it to work?
    DLC
    * Dennis Clark Aristocrat at heart dlc@v... www.verinet.com/~dlc *
    * Be well, do good work, and stay in touch -- Garrison Keillor *
    edited 2000-03-20 16:34
    > I thought I had the same problem. When I first got my stamp, I couldnt get
    > it to download. "Stamp not found" etc. Turns out that my computer would not
    > access the serial port from the stamp program when windows was running. (win
    > 98se on a packard bell 850) I had to boot my computer with the "emergency
    > start up disk" and run the stamp program from there at the a: prompt.
    > My final solution after I got tired of doing that, was to get an old (free)
    > Windows 3.1 laptop and use that for stamping.
    Have you tried the newer stamp2w.exe program? It is a full GUI for Windows
    OS. Its still a little rough, if you don't use the "standard" fonts then
    some of the windows don't scale well, but, overall it is an improvement over
    the old DOS stampII.exe or stamp2sx.exe programs.
    DLC
    edited 2000-03-20 23:15
    Question #1: has it worked before? if so- ignore the following.
    edited 2000-03-23 23:17
    Dear Matt·
    Be observed it fails in humid days.·
    In case positive, enter in contact fassystem@robos.com.br·
    Fernando Santana
    www.robos.com.br
    Original Message
    Sent: Friday, March 24, 2000 1:30 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Hey, broken stamp II...HELP!!!
    Well, it worked at first, and then within about two weeks or so, maybe a month it just didn't work any longer.· Any suggetsions before i go spend more money on a new stamp?· I am gonna talk to parallax soon, but if anyone has any suggestions that would be great...Thanx
    -Matt/Vid
    eGroups.com Home: http://www.egroups.com/group/basicstamps
    www.egroups.com - Simplifying group communications
    -Matt/Vid
