Driving 7 segment displays ? — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2000-03-21 22:28 in General Discussion
Hi,
I am working on a dark room timer that uses the Stamp1 as a count down clock
for my enlarger. So far I am doing good, everything works as expected, but
now, I want do away with my 1 minute mechanical timer completely.
I am currently using a BCD to 7-segment display driver (7447) to make the
numbers 0-9, this takes 4 pins from the stamp. I would like to add another 7
seg. display, but If I do that, I won't have any pins left for the 'Set' and
the 'Start' buttons or the transistor fired Relay "With Suppression Diodes!
[noparse];)[/noparse] "
Does anyone know of a 'Serial to 7 segment display driver chip' or maybe
just a serial to BCD? Or maybe even a better way of doing this with
something better than the 7447.
This project doesn't warrant the use of a Stamp2 or sx, the code is simple
and minimal, and since I have the Parallax PIC programmer, I can fry this
into a 16C58A when it's done, and free up my Stamp1.
Chris
  • ArchiverArchiver Posts: 46,084
    edited 2000-03-18 04:59
    A great device for this is the maxim MAX7219. It can handle up to eight
    digits and only takes 3 lines on the stamp. You can control the number of
    digits (and brightness!) in software. The interface code has already been
    done (Scott Edwards). Get the chip at:
    http://www.maxim-ic.com
    Get the code at:
    ftp://ftp.nutsvolts.com/pub/nutsvolts/library/stampaps/st_ap10.pdf
    Best, Duncan
    edited 2000-03-18 09:38
    At 11:16 PM 3/17/00 -0500, you wrote:
    >Hi,
    >Chris
    If you use 74164's you can create your own Characters within the 7-Segment
    Display (7SD) configuration by connecting the outputs of the 74164 directly
    to the 7SD and sending the proper 8-Bit pattern to light the appropriate
    segment (The 8th bit could be used to drive the decimal point) ... or you
    could combine each 74164 with two 7447's and drive two 7SD's to use the
    standard 7SD characters. Either way you will only need two stamp pins
    (CLOCK and DATA), three stamp pins if you want to make use of the CLEAR on
    the 74164, although if you use the SHIFTOUT function on the stamp you
    shouldn't need to use the CLEAR. When the SHIFTOUT does it's thing there
    will be a brief flicker in the display during the updates anyway without
    needing to CLEAR. To CASCADE more than one 74164, connect all of the
    clock's(Pin9) in common with one another, connect Qh(Pin13) of the first
    74164 to the Serial Inputs (Pin1 & Pin2 - OK to connect these two pins
    together) of the second 74164 and so on..., and if you choose to use the
    CLEAR(Pin9), connect all of the CLEAR's together, otherwise connect all of
    the CLEAR's to Vcc(+5V). Remember to put a .1uF or .01uF across each
    74164 as close as possible to pins 7 and 14 ... a good measure for any IC
    especially counters, dividers, shift registers, etc.
    edited 2000-03-20 03:03
    Thanks Duncan and Beau for the help, I think I'll try Beaus idea first,
    because it costs less and I only need 2 digits on this project. I have
    another question though; I have a bunch of 4013s (CMOS Shift-Registers?)
    and would like to know if there is a law against using TTL and CMOS in the
    same circuit? It just doesn't seem right to me. I was thinking that while I
    wait for my 74164's, I might experiment with using them and the 7447 to
    drive my displays. Any 'Red Flags' or warnings about TTL+CMOS circuits
    would be welcome.
    Chris
    Original Message
    From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3JjF57wFFCghcF2iZL-NEtmpovVwJrCwDiUJeEgvjowzz3Z_rrCPnRshx1g20KHFvBlmrIaK_l9njo24atpDPw]bschwabe@H...[/url
    Sent: Saturday, March 18, 2000 4:39 AM
    To: basicstamps@egroups.com
    Subject: [noparse][[/noparse]basicstamps] Re: Driving 7 segment displays ?
    >Hi,
    clock
    7
    and
    >Chris
    eGroups.com home: http://www.egroups.com/group/basicstamps
    http://www.egroups.com - Simplifying group communications
    edited 2000-03-20 03:46
    HI Chris,
    TTL and CMOS are fine together.. ( I also have a load of 4000 series CMOS ICs ).
    The only restriction is that TTL is a 5.0 volt system so don't try any higher
    voltages.
    in some critical timing logic set ups the timing of CMOS and TTL need to be
    checked.
    Also the current draw from TTL is high so be careful you don't overload the
    STAMP's regulated
    5.0 volts, if you are using this.
    To: <basicstamps@egroups.com>
    Date sent: Sun, 19 Mar 2000 22:03:31 -0500
    Send reply to: basicstamps@egroups.com
    > would be welcome.
    > Chris
    Original Message
    > From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=N_NN_habv8EWt7SUHrxC32lzCt_7TYHoCipwM6L1bnjEchatgdV1kmS8LBB0iuhdFgq7J6pb7wPVOPcFHbmHb00]bschwabe@H...[/url
    > >Hi,
    > clock
    > 7
    > and
    > >Chris
    > -- Easily schedule meetings and events using the group calendar!
    > -- http://www.egroups.com/cal?listname=basicstamps&m=1
    ron... the motor man...
    Ronald Doctors
    http://www.members.home.net/rdoctors
    edited 2000-03-20 03:51
    Yes!, you can use the 4013's
    CMOS --> TTL (Same Supply Voltage)
    CMOS (Any gate) >
    o
    > TTL (Any gate)
    | 1K
    o--/\/\--> GND
    TTL --> CMOS (Same Supply Voltage)
    TTL (Any gate) >
    o
    > CMOS (Any gate)
    | 2.2K
    o--/\/\--> +5V
    >would be welcome.
    >Chris
    Original Message
    >From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NiC-NW-pbUtoy2HoI1PpuXEhxDgpR0WMrFJMTvtVctstEOBRq-9QG5TBAxhe9pvLhmniuhNowUpiccdTgcyP]bschwabe@H...[/url
    >>Hi,
    >clock
    >7
    >and
    >>Chris
    Well, I think I have it all Ironed out finally. One problem did come up
    though. The BS1 does'nt have a 'Shiftout' command. The BS2 works fine with
    the 4013.
    So, maybe I'll do the 'Time-Share' method with the transistors, unless
    someone knows how to fake a shift-out in the stamp1.
    Chris
    Original Message
    From: Beau Schwabe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nbOlsJjaX9c43WJv4kEbfXm4PLMF9NJ15mKQargI8w4rRNqYQEyWRJWmy1uWty1S02ibPgd24PcuiH6nAyeowDQvIQ]bschwabe@H...[/url
    Sent: Sunday, March 19, 2000 10:52 PM
    CMOS (Any gate) >
    o
    > TTL (Any gate)
    | 1K
    o--/\/\--> GND
    TTL (Any gate) >
    o
    > CMOS (Any gate)
    | 2.2K
    o--/\/\--> +5V
    >would be welcome.
    >Chris
    Original Message
    >>Hi,
    >clock
    but
    >7
    >and
    Diodes!
    >>Chris
    eGroups.com Home: http://www.egroups.com/group/basicstamps/
