Analog relative movement sensor — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2000-03-21 01:06 in General Discussion
I'd like to monitor the slippage dynamics of a human head-mounted device
during rapid head movements. Slippage is largely due to skin movement
under the head strap, relative to the skull. Ideally, I'd like something
like a Hall-effect device mounted on the slipping head strap, sensing
position of a very small magnet taped to the skin. But these devices
produce digital pulses (not analog distance) when near the magnet. I
would prefer an analog output sensing relative movement of sensor and
reference maker over a small range of 5-10 mm. Any suggestions will be
welcome. I'm still scratching my (slipping) head over this one.
Dennis
  • ArchiverArchiver Posts: 46,084
    edited 2000-03-20 23:25
    There are Hall-effect sensors with analog output. I do not remember
    the manufacturer's name, but I believe that thru a web search you could
    easily find it.
    ACJacques
    > Dennis
    > eGroups.com home: http://www.egroups.com/group/basicstamps
    > http://www.egroups.com - Simplifying group communications
    edited 2000-03-20 23:37
    Hello All
    A wonderful supplier of Hall Effects and information is Allegro
    Microsystems.
    http://www.allegromicro.com/
    Another is the Microswitch company, I don't have their web address.
    Look at http://www.plano.com/mfrz.htm for all component manufacturers
    web sites.
    Jack Wilker
    You can get linear Hall sensors that can respond to angular changes.
    Honeywell and others make them . They are not expensive and very simple to use.
    They are a bit power hungry so battery powered systems might be a challenge if
    you need
    tracking for a long time.
    I have some very small magnets about 0.2" x 0.2" x .05 "( Rare earth type )
    that could be used.
    An alternate method that springs to mind is to use an optical pattern on the
    skin and use
    moire fringes to detect movement..
    Date sent: Mon, 20 Mar 2000 20:25:33 -0300
    To: basicstamps@egroups.com
    Send reply to: basicstamps@egroups.com
    Subject: [noparse][[/noparse]basicstamps] Re: Analog relative movement sensor
    > easily find it.
    > ACJacques
    > > Dennis
    ron... the motor man...
    Ronald Doctors
    http://www.members.home.net/rdoctors
