LED moving display
ArchiverArchiver Posts: 46,084
edited 2000-03-15 - 22:35:00 in Microcontrollers
Hi all,
anyone know how to use Basic Stamp to control a LED moving display ?
Pls. let me know how to do this.
thank you
  • ArchiverArchiver Posts: 46,084
    edited 2000-03-15 - 22:34:00
    Depends what kinda display you mean... Do you mean a dot-matrix display, or
    a seven-segment display. I wrote some BS2 code to scroll messages on a
    display. I also wrote some PBC (prett much a BS1)code to do the same thing.
    This is not an easy undertaking. If you have patience go ahead and try.
    let me know what kind of display your using, then maybe I can help more.
    >From: "Felix Chan" <flexchan@h...>
    >Reply-To: basicstamps@egroups.com
    >To: basicstamps@eGroups.com
    >Subject: [noparse][[/noparse]basicstamps] LED moving display
    >Date: Wed, 15 Mar 2000 08:01:03 -0800
    >Hi all,
    >thank you
    >-- Check out your group's private Chat room
    >-- http://www.egroups.com/ChatPage?listName=basicstamps&m=1
    ______________________________________________________
    OOPs should have said my code is for the 7-segment displays hooked up with a
    MAX7219
    >Hi all,
    >thank you
