problems when bs2sx is not connected to desktop — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2000-03-14 01:58 in General Discussion
Sounds to me like you have a ground problem. Make sure all your grounds are
tied together somewhere.
Just a guess.
Al Williams
AWC
*Read a PS/2 keyboard from your Stamp or other microcontroller project.
http://www.al-williams.com/awce/pak6.htm
Original Message
> From: Steve Znavor [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=P-9ZA4p_aX8uF-ksPFrbIK9ooDlN6dqzvSU5DpfSZ96Js7OXdUwi0jgLzxPjIXBdkoVVus-VzPVgr8CPMyHy]sznavor23@h...[/url
> Sent: Sunday, March 12, 2000 9:06 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] problems when bs2sx is not connected to desktop
> When i run my BS2SX program by hitting the "run" icon on the basic stamp
> editor and the debug screen pops up the program runs absolutely
> perfect...but when i turn off power and disconnect my BS2SX from
> my computer
> (its running by itself now) and then power it back up the stamp
> works only
> every now and then barely ever--i dont get it. Is there
> anything i can do
> to fix it?
> ______________________________________________________
  • ArchiverArchiver Posts: 46,084
    edited 2000-03-13 10:06
    perfect...but when i turn off power and disconnect my BS2SX from my computer
    (its running by itself now) and then power it back up the stamp works only
    every now and then barely ever--i dont get it. Is there anything i can do
    to fix it?
    Get Your Private, Free Email at http://www.hotmail.com
    Steve:
    For what its worth: I had a stamp running with only a serial lcd attached,
    which would run perfectly while attached to the computer. When the cable
    was removed from the stamp, the program would not run. Reset and power
    up/down had no effect. It turned out that the problem was that I was
    driving the display with a desktop power supply, and the stamp with a line
    transformer. Apparantly the slightly different grounds caused a problem.
    Once I powered the stamp from the desktop power supply it ran
    perfectly...cable or no.
    >From: "Steve Znavor" <sznavor23@h...>
    >Reply-To: basicstamps@egroups.com
    >Date: Mon, 13 Mar 2000 03:06:00 GMT
    >computer
    >to fix it?
    >eGroups.com home: http://www.egroups.com/group/basicstamps
    >http://www.egroups.com - Simplifying group communications
