need magnetic sensor — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2000-03-14 00:20 in General Discussion
The device you want is called a Hall effect sensor. I know that you can get
them from Mouser or Digikey- Radio Shack might also have them. They are
pretty cheap, if memory serves.
peter
Peter C. Charles, Ph.D.
Research Assistant Professor
Department of Microbiology and Immunology
Rm. 730 Mary Ellen Jones Building, CB# 7290
UNC
Chapel Hill, NC 27599-7290
  • ArchiverArchiver Posts: 46,084
    edited 2000-03-14 00:10
    Use the latching type of hall sensors cost about $0.99 each PT number HI400 and
    are available from ( Jameco. #169691).
    The latching ones have no bounce but do need a reverse polarity , that is a N
    and sth pole at each location.
    It's worth the effort to sue them as they much more relaible than reed switches
    and do not break.
    To: <basicstamps@egroups.com>
    Date sent: Mon, 13 Mar 2000 11:04:25 -0500
    Send reply to: basicstamps@egroups.com
    Subject: [noparse][[/noparse]basicstamps] Re: need magnetic sensor
    > peter
    > UNC
    > eGroups.com home: http://www.egroups.com/group/basicstamps
    > http://www.egroups.com - Simplifying group communications
    ron... the motor man...
    Ronald Doctors
    http://www.members.home.net/rdoctors
    There are also non latching hall sensors and they only need one polarity this
    will be much
    easier to use for quick pulses they have a fairly high freq. response (how many
    times they
    can sense in given period)
    and are available from ( Jameco. #169691).
    switches and do not break.
    > From: "Dr. Peter Charles" <pcharles@m...>
    > > peter
    > > UNC
    > Ronald Doctors
