EEPROM ID please??? — Parallax Forums
EEPROM ID please???
Velvet LeopardVelvet Leopard Posts: 47
edited 2004-08-20 00:24 in General Discussion
I have a chip board that has an 8-pin surface mount EEPROM on it with the number:· 9877 2J64 on it. I have searched high and low for info on the thing to no prevail.· It has no logo on it.· The board is from Elpida Memory, but looking there, I didn't find it.· Maybe they hid the info?· Or got the chip from somewhere else?· I really need to know about this chip.· I found a spec sheet on the board.· It shows how the EEPROM is connected to the boards circuitry.· It shows pin connections:· SCL, SDA, SA0, SA1, SA2, Vcc, Vss, and NC on the last pin.· I am not sure of the pin numbers though, no separat sheet for the EEPROM chip.· The data sheet describes the chip as·a Serial PD.· Thanks.
Post Edited (Velvet Leopard) : 8/20/2004 12:24:20 AM GMT
    If you get lucky, it's a standard I2C memory like the 24LC64.· If it is, you can connect to it using routines I posted in another thread.· I found a spec sheet here:
    http://www.kollar.com/observatory/dome/parts/24lc64.pdf
    Jon Williams
    Dallas Office
    Post Edited (Jon Williams) : 8/20/2004 12:34:21 AM GMT
