rechargable light-weighted batteries for 2p40 — Parallax Forums
greengreen Posts: 6
edited 2004-08-08 08:22 in BASIC Stamp
Hi,
··· Does anyone know any rechargable batteries (along with the recharger or recharging-circuit) that I can use to run a 2p40 along with two typical IC's and 2 LEDs? I need it to be light-weight (less then 20 grams).
  • hanksterhankster Posts: 5
    edited 2004-08-08 04:34
    You can try one of the 5 cell packs (6v) or buy the cells in bulk and build your own - http://www.hobbyshopper.com/batteries.html
    They weigh about 20 grams (5 cell pack) and are 150mAh NiMh cells. They can be charged using a trickle charger outputting 15mA... normal charge time is 18 hours at this rate.
    I am using a modle electric airplane battery.· Rated at 7.4 volts and 1800ma - weighs 62 grams and is about one-third larger that a 9V battery.· This came with an R/C airplane and it included a recharger.
    Since the voltage regulator would like as close to 5.5 volts as possible because it throws off more heat, I am happier with this than a 9volt cell and it weights less than 4 AA cells - plus much more output
