Noritake VFD display — Parallax Forums
Christopher41877Christopher41877 Posts: 5
edited 2004-07-29 02:54 in BASIC Stamp
Hi,
I was using a BPI-216 serial display from Seetron and I switched to a VFD display from Noritake.· It's a serial display, 1X14, and runs at 9600.· Does anyone know where I can find sample codes to get this thing to work?
Chris
  • steve_bsteve_b Posts: 1,563
    edited 2004-07-29 02:06
    If it runs the Hitachi communications standard then your code shouldn't be any different (less the 2line display).
    Might have to change your baud rate.
    Have you already interfaced the BPI display?
    Steve
    http://members.rogers.com/steve.brady
    http://www.geocities.com/paulsopenstage
    "Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
  • Christopher41877Christopher41877 Posts: 5
    edited 2004-07-29 02:33
    Yeah,
    I kind of thought I would have this problem so I just wrote a simple code to say "hello" with the BPI, made sure it worked and then took the Noritake and tried it.· This is a brand new display but I was hoping it worked like thier other displays.·
    I'm just thinking about my displays.· I'm pretty sure they either run at 2400 or 9600.
    you might want to check your baud rate as a quick start!
    Steve
