Forum editor debug extravaganza - Page 2 — Parallax Forums
2»
  • @AwesomeCronk said:
    I must say this is the most hilariously productive thread I’ve ever read.
    Did you by chance see someone flying past your windows today, wearing a special getup? [Wingsuits not eligible.]
    Because you're right.
    Mascot outside in the snow.
  • VonSzarvasVonSzarvas Posts: 3,278
    edited 2021-02-03 07:11
    @Wuerfel_21 said:
    Still unrelatedly, I figured out how to do even larger text. This terrible art must be kept secret.
    Ha ha!! Yes!!!
    I was thinking about disabling the ???? tag when I saw your earlier post, but then figured, what would be the fun in that !
  • evanhevanh Posts: 15,192
    Doesn't load the server, nor create/use bloat. Browsers handle it gracefully, easy to scroll through.
  • GIF uploading is no longer gonked?!?!
  • I really appreciate all the hard work going into smoothing out the kinks in the new forum software. Thank you @VonSzarvas and @Wuerfel_21 and anyone else for the time you spend on it.
    If I may suggest: Wouldn’t it be nice if the “New” posts markers were Left-justified before the Title name?
    Paul
  • doggiedocdoggiedoc Posts: 2,239
    edited 2021-02-04 00:18
    Does “tagging” a user still work? @doggiedoc
    Edit: It would appear not.
  • This is the thread for random experiment spam posts, actual requests and problems go in the other one.
    Already discussed, AFAIK not possible without DOM modification
    Yes, @VonSzarvas tagging is gonked
  • Actually, it does work in that I got a notification when @Rayman mentioned me, it just doesn't link the user inside the post anymore, which eh idc
    Correct. That's a "feature" of this editor which will require some effort to play nice with the @ @@ @@@ code symbols. Time will see that improved.
  • Oh, and does @-ing with Quotes work? (as is necessary when a user has a space in their name) @"VonSzarvas"
