Shop Learn
hand solderable usb component — Parallax Forums
max72max72 Posts: 1,152
edited 2021-01-04 20:53 in General Discussion
From time to time I create a custom board for my needs.
Up to now I had an USB mini connector, to be used for voltage supply, and in some cases programming.
like this one: https://www.mouser.it/ProductDetail/798-UX60A-MB-5ST/
USB mini are phasing out, micro are widely used and USB-C is looking like the new standard.
Could you suggest some connectors to be used on a custom board, that is reasonably easy to solder?
Thanks in advance,
Massimo
