flexspin compiler for P2: Assembly, Spin, BASIC, and C in one compiler - Page 73 — Parallax Forums
17071737576116
  • JRoarkJRoark Posts: 1,214
    edited 2020-12-26 20:44
    @ersmith I cant really call this a bug, but here goes. In 5.0.3, if a function is defined to return string, but no return value ever gets assigned prior to exiting the function, the function returns garbage instead of an empty string. This demonstrates it.
    print "["; BadFunc$(); "]"
    FUNCTION BadFunc$() as string
        ' nothing here.
    END FUNCTION
    From a C point of view, this is a natural expectation when you don't specify a return value, but in BASIC the mantra is "all strings get initialized to an empty string". Is there any way to change this behavior so that a "safe" default return value (empty string) gets set up by the compiler automatically?
    Edit: FWIW, the return value of an empty function that returns an integer or float correctly returns zero, so it is only the string-type functions that return uninitialized data.
    edited 2020-12-27 00:21
    Eric,
    When using spin2, I note that flexprop (v5.0.3) does not set the hub locations $44 and $40 for clkfreq and clkmode, but it does indeed load correct values when clkfreq and clkmode is used.
  • JRoark wrote: »
    Actually it always returns a NULL pointer (0). It's the printing function that's going "wrong", printing garbage (whatever happens to be at memory location 0) rather than something else. This patch causes it to print nothing instead:
    --- a/include/libsys/fmt.c
    +++ b/include/libsys/fmt.c
    @@ -834,6 +834,7 @@ int _basic_print_string(unsigned h, const char *ptr, unsigned fmt)
         TxFunc tf = _gettxfunc(h);
         if (!tf) return 0;
    +    if (!ptr) return 0;
         return _fmtstr(tf, fmt, ptr);
  • Cluso99 wrote: »
    Eric,
    FlexProp, like Tachyon, p2gcc, riscvp2, MicroPython, and I believe Catalina, uses locations $14 and $18 for these. It's Spin2 that's the odd one out, but Chip decided to go his own way.
    ersmith wrote: »
    Cluso99 wrote: »
    Eric,
    typical :(
         if (!tf) return 0;
         if (!ptr) return 0;
    That works nicely! Thank you.
  • @ersmith Flex V5.0.3: I found a case where the compiler throws a "fatal" error, but the compiler will still finish the compile and download it anyway. This code shows it:
    	dim i as long
    	dim x as long
    	for i = 1 to 10
    		x += 1
    	next x	'<-- note x instead of i
    The code outputs the appropriate compiler error: Wrong variable in next: expected i, saw x but this does not trigger the compiler to abort. If you're not watching the compiler output pane in FlexGUI, you'll miss it, and the code loads and runs, albeit with potentially odd results.
  • @ersmith What is this error trying to tell me?
    d:/Flex2Gui/flexgui/bin/flexspin" -2 -l -D_BAUD=230400 -O2 -Wall   -I "d:/Flex2Gui/flexgui/include"  "d:/Flex2Gui/flexgui/P2 Libs/Generator Project/GPS-RTC-Serial-VGA-TestP2-NOVGA.bas"
    Propeller Spin/PASM Compiler 'FlexSpin' (c) 2011-2020 Total Spectrum Software Inc.
    Version 5.0.3 Compiled on: Dec 22 2020
    |-DS3231RTC_P2_V2.spin
    |-DateTimeLibP2.bas
    |-|-PropellerLibP2.bas
    |-|-BitLibP2.bas
    |-|-StringLibP2.bas
    |-StringLibP2.bas
    |-CommonLibP2.bas
    |-simple_serial.spin2
    |-PropellerLibP2.bas
    |-ANSILibP2.bas
    |-ansi.spin2
    |-|-timing1024x768.spin2
    |-|-unscii-16.spin2
    |-|-vga_tile_driver.spin2
    fmt.c
    strings.bas
    stringlibp2.bas
    float_support.c
    posixio.c
    bufio.c
    errno.c
    memset.c
    error: Internal error exceeded local register limit
    child process exited abnormally
    Finished at Sun Dec 27 12:00:21 2020
  • error: Internal error exceeded local register limit
    Means the code needs more local variables than can fit into cog RAM. In my experience, disabling the CSE optimization pass ("-O2,~cse") fixes it. The GUI doesn't really have an option for this other than to go down to -O1 ("Default Optimization")
  • RaymanRayman Posts: 13,797
    What causes this message? I assume something to do with fopen()... Code appears to work though...
    1>Done.
    1>Program size is 70980 bytes
    1>The filename, directory name, or volume label syntax is incorrect.
    ========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
  • JRoark wrote: »
    	dim i as long
    	dim x as long
    	for i = 1 to 10
    		x += 1
    Ah, interesting -- that one was a special case error that doesn't go through the normal error routines, and I forgot to flag it. Thanks for the bug report!
  • Wuerfel_21 wrote: »
    Yes, @Wuerfel_21 has good advice here. The other possible source of the problem is a function that is just too complicated to compile, but that's much rarer.
  • Rayman wrote: »
    1>Done.
    That's very bizarre. I don't even know what program is printing that. Did you run flexspin from make or something? Perhaps your make program doesn't like the file name you used -- does it have spaces in it or something? As near as I can see flexspin itself shouldn't print anything after the "Program size is xxx bytes".
  • evanh wrote: »
    I thought those threads settled things too and that we had all agreed on $14 and $18 for the clock frequency locations. Apparently only "almost" all of us agreed :). I do wish Spin2 would use the same convention as everyone else though.
    Nevermind... It was a bad comment in my batch file that does the build...
    Tried to use "//" instead of "REM"...
  • @Wuerfel_21 and @ersmith: Good input. Thank you both. Backing down the optimization level to "default optimization" fixes it. (FWIW, the code is something on the order of 10K lines once you count all the libs in, so it may be approaching the "too complicated" limit. Dunno!).
  • JRoark wrote: »
    FWIW, the "too complicated" limit is per-function, so breaking up large functions into smaller ones may help.
  • Could it be that the built-in symbols for events and interrupt sources are not implemented in FlexSpin? (for example, EVENT_SE1) All the other predefined symbols for smart pins (P_PWM_SAWTOOTH, P_OE, P_ADC, ADDPINS...) seem to work. Ok, I know, in C I have to #include propeller2.h but in spin2 files the symbols should be there without special actions, shouldn't they.
  • ManAtWork wrote: »
    Yes, they're missing in 5.0.4. I'll add them in 5.0.5, thanks for pointing this out.
    Is there a simple way to tell the size of a file when using Plan 9?
    That FSEEK way doesn't seem to work...
  • Rayman wrote: »
    That's a bug then, and I'll try to fix it.
    Another way to check the size of a file is with the stat() function:
    #include <stdio.h>
    #include <sys/stat.h>
    int main()
        int r;
        struct stat s;
        mount("/files", _vfs_open_host());
        chdir("/files");
        r = stat("filesize.c", &s);
        if (r) {
            perror("Unable to stat file");
            return 1;
        printf("size of file: %ld\n", s.st_size);
        return 0;
    That looks good! Is it part of fatfs or plan9?
  • Rayman wrote: »
    stat() is a standard file system call and should work with all file systems.
    That's great, thanks! It's amazing how little C I know, even though I'm pretty good with MFC C++. MFC really spoiled me I guess...
  • I just noticed a strange behaviour of the compiler. I hope it's not one of my stupid mistakes, again...
    This is inside a DAT section of a spin2 file:
                rdlong  theta,ptra ' works as expected
                rdlong  theta,ptrs ' typo, correctly throws an error, ptrs is undefined
                rdlong  theta,ptrs[4] ' does NOT throw an error!
                rdlong  theta,foo[4] ' any symbol seems to be ignored, foo is undefined
                rdlong  theta,foo[0] ' bad constant expression ???
    There was a bug in the parsing of ptrx[n] type operands that caused errors not to be detected. Thanks for noticing this, it should be fixed now in github.
    edited 2021-01-03 18:31
    @ersmith Have you thought about adding the long filenames option to FatFs?
    Or, is it already there?
    Also, is there a way to change which pins are assigned to the uSD card?
  • evanhevanh Posts: 15,126
    SD booting doesn't much like long filenames. There has been failed boot confusion when they've been used.
    edited 2021-01-03 21:05
    Are you saying using any long filenames will break the boot from sd process?
    Or, that people are trying to boot from files with long filenames and it doesn't work?
