demo of FullDuplexSerial4port ?
RS_Jim
Does anyone have some code showing the use of this object with 3 or more ports?
Jim
Jim
--demo1 is a single port of the 4 opened for debug, that's all.
--demo2 opens 3 ports, one for debug, one for receiving data from outside, and one to fake that external data by sending it from another cog "asynchronously". That uses RTS/CTS flow control between the cogs.
-- demo4 shows the setup for an open baud mode, as you might use for multidrop or RS485 to a single rx/tx pin.
There is a fourth file, dataIO4port.spin, that handles the numeric formatting and such for the demos.
I should note that these are for the original program that Tim Moore developed. He included a demo with the distribution, a demo that involved communication with GPS and other devices.
I mostly use a version of FDS4port now where I've stripped out the flow control and made other changes and bug fixes as well.
Jim
Jim
Just to be clear, Tim's ultimate version was pcFullDuplexSerial4FC.spin. <http://forums.parallax.com/discussion/104231/multiple-port-serial-driver/p1>
Where "FC" stands for flow control. He added flow control in response to forum requests. Some time later I modified his code to the "4port" suffix, and later to the version I use now, which has the flow control stripped out. Other folks here have come up with their own versions as well. So, no wonder there is a bit of confusion!
