KISS Eval board (obsolete, no longer shipping)
ManAtWork
My KISS board is a P2 evaluation board that is kept as simple as possible (KISS = keep it simple, stupid). It can be used for standard breadboards or to be mounted on to of a custom PCB to avoid soldering of fine pitch SMT parts. I think this is ideal for prototyping or low volume "embedded" products.
If you plan to use the P2 as "self contained" computer with VGA/HDMI display there might be better solutions like Cluso's RetroBlade2.
Feature list, schematics and genral discussion, refer to this thread.
To allow for different pin header options I sell the board together with the pin headers but only with the SMT parts and the power terminal soldered. So you have to solder the pin headers by yourself. There are many different possibilities:
1. put double row pin headers on the top side. This gives 8 sockets that are pin compatible with Parallax' P2 EVAL accessory boards.
2. put single row pin headers into the outer rows on the bottom and the inner row an the top side. This configuration fits into a standard breadboard (explanation here). Even pins can be used directly on the breadboard, odd pins can be connected with Dupont wires.
3. put female headers on the bottom side
4. mix of 1..3 or anything you like
Extended version with additional SD card socket and mini USB connector for 5V power instead of screw terminals, see this picture.
How to order:
no longer available, not recommended for new designs.
If you need replacement parts please contact me offline at info@benezan.de
How to order:
Production status:
132 boards produced and tested,
72 EU stock, 16 USA stock
Doc
But there will be more to it than just tossing the parts in to the oven . I'm sure you already know that.
Let's just wait for a MAW response.
I think the challenge would be good. Surely if I can replace the P2 on my EVAL board I can assemble a bare board.
Surely. (I do enjoy a challenge.)
All I know is I would not be able to beat his P&P robot in precision plus I get the benefit of a tested and working board and do not have to spend time and material to build the test rig. MAW is a PRO. That's why I took 2 boards at once.
And please note that it might be cheaper to order some PCBs from JLC because shipping is expensive for me. The gerber files are in the discussion thread, feel free to use them.
How many potential buyers for North America do we have? I'm set up to ship 20-30 boards from Ray and Peter right now. I have all the shipping supplies, label makers and stamp machine to ship to USA and Canada.
Doc
I've updated the status in post #4.
I'll ship 2 boards to Maciek. 6 are dispatched for Publison (USA) and 4 to Thailand.
cheap (by sea): 19.90€
express (airmail): USA 36,80€, Thailand 39,60€
The alternative option would be to wait longer or use cheaper but unpredictable overseas shipping.
Thank you!
Video:
