FTDI EVE3 GPU --> VGA
Rayman
in Propeller 2
It works! Hardware took some time to get going, but software was a snap.
Currently just using the default timings for WVGA display (800x480).
Need to adjust these, but it works!
Just populated and baked this expansion board today. It's got a BT816 EVE3 GPU coupled with a ADV7125 3-channel DAC.
There's also a couple tiny chips to select sync signals between P2 and EVE. It's rigged so can output VGA either from EVE3 or P2.
Screenshot isn't the fanciest, but I don't have any way to push the button
Refresh rate is 54 Hz, a bit low, but should work on most monitors.
This is a nice one.
Wasn't sure it would work with EVE3.
Thought I might have had to wait for EVE4...
Looks like it works with newer monitors as VGA.
But, when using my VGA->HDMI adapter, it's recognized as 600p and only shows a part of the screen Maybe the sync polarity is off or something...
Got HDMI to recognize as 720p on 2 out of 3 monitors by playing with horizontal settings. But, it's not filling the screen entirely...
I'm guessing it's the VGA->HDMI adapter having a hard time decoding the VGA signal...
Maybe need to tweak the timings some more...
The bottom is a bit cut off on this TV, but not on the monitors. Think that's the TV cutting off the edges...
