Cluso's RetroBlade2 Single Chip Computer (pcbs arrived) - Interested??
Cluso99Cluso99 Posts: 16,676
edited 2020-10-26 - 20:23:50 in Propeller 2
This post and the next have been updated with the latest info. There is only one pcb as it can do VGA and brings out the I/O on 0/1" header underneath the VGA connector.
KiCad passes all the design rule checks. It's all laid out now and the gerbers look good. Just need to panelise and send off. Let me know below who wants them.
2020-10-13: Boards ordered - should be back in ~2 weeks :sunglasses:
2020-10-26: Boards arrived - looking good :sunglasses:
Cluso's P2 RetroBlade2
* PCB 1.6"x2.2" 2 layer ENIG 1.6mm FR4
* P2X8C4M64P chip of course (some initial boards may use P2 RevB chips - let me know if you need RevC)
* 20MHz xtal
* Requires 5V regulated input (from one of: headers, microUSB, or USB/TTL header)
* 3V3 1A LDO SOT-89 regulator
* 1V8 generated by series 3V3 1A LDO SOT-223 to 1V8 1A LDO SOT-223
* Proper bulk and bypass capacitors
* Transistor reset circuit (as per P1) configured with solderable link
* microSD socket (microSD card not supplied) - can boot direct from microSD without Flash
* Two microUSB sockets - for power / keyboard / mouse (cables available from fleabay for ~$1.50)
* P00-15 brought out on 1x20pin 0.1" header
* P16-31 brought our on 1x16pin 0.1" header (under VGA connector)
* P32-47 brought out on 1x20pin 0.1" header
* P48-49 brought out on microUSB connector
* P50-51 brought out on microUSB connector
* P52-57 brought out on tiny 0.4mm thru-hole pads (will take single AWG30 kynar wire-wrap wire)
* P58-61 used internally for microSD and (optional) SPI Flash
* P62-63 brought out on 1x6 0.1" header (serial port) for Reset/SerialOut/SerialIn/5Vin/Gnd/nc - compatible with CP2102 USB/TTL 6pin (not supplied - fleabay ~$1.50)
* Note: P27-31 also connects to VGA socket (if fitted) for video/LCD (connector overlays the P16-31 header)
* Optional SOIC-8 footprint on underside for Flash W25Q32JVSIQ/W25Q64JVSIQ/W25Q128JVSIQ (4/8/16MB Flash)
* Through hole parts supplied but not fitted/soldered
* Can run my P2 OS and Z80/CPM emulation
Notes:
* The regulators will likely self-limit to somewhere in excess of 500mA. Switchers are not used.
* The 3d image shows the wrong microSD and microUSB connectors. Peter showed the ones I'm using on his P2D2 thread the other day.
* A 1x2pin 0.050" header/link enables the 10K pullup resistor (fitted as standard) for booting from the (optional) Flash chip
Cost will be US$40 without Flash, US$45 with W25Q128JVSIQ (16MB) and US$5 unregistered airmail post from Australia (you take the risk).
  • Cluso99Cluso99 Posts: 16,676
    edited 2020-10-13 - 06:51:36
    Schematic
    1123 x 775 - 285K
  • Gerbers looking good as are the paste pads under the P2 :sunglasses:
  • Since you are not using the other I/O near the VGA why don't you hook up the I2C PnP on the VGA just for the fun of it? Also the SD pulldown value should be 1M since the card's pullup is fairly weak.
    (my pcbs were just a tad behind my parts shipment and will be here Monday)
    edited 2020-10-10 - 03:24:00
    I am not certain that I am going to fit that resistor anyway but thanks for the value info. 100K 0603 is the largest value I have in stock. The ROM code just checks for a pullup (ie a floating or pulldown is detected as not a pullup).
    Probably would have been useful to put I2C (and maybe other connections) on the VGA connector but it might be too late as I would have to check everything again as I'm not comfortable to rely on KiCad yet.
    BTW I checked the drill files for the slots - nice and simple :)
  • Let me know which components you need as I will also send 1M 0603s
  • Cluso99,
    I really like the RetroBlade and would want one when it becomes available. Could you do a variant with HDMI and two RCA audio connectors?
    edited 2020-10-10 - 07:01:46
    Ahle2 wrote: »
    Cluso99,
    Depends how this board goes. HDMI can be done with a fleabay cable (with the conversion chip).
    I presume the audio is the same as P2 (ie RC plus isolation cap)? Presume a 4u7F or 10uF MLCC will work for the DC isolation and an RC of 1K and 100nF IIRC. Is more than one channel required?
    I think an addon board that the RetroBlade could plug into might be better for these extras.
    Of course it will plug into Peter’s 0.050” protoboard which i plan to offer too :) Honestly don’t know why this hasn’t been done years ago. Probably it’s too obvious - haha.
  • Heck, I'm gonna want every variant out there. This and KISS, without a doubt :+1:
  • Cluso99 wrote: »
    Probably because it was far too expensive and we always had the dilemma of mixing thicker 100mil pins etc. I wasn't charged anything extra to get 3,996 holes drilled on each board.
  • Cluso99 wrote: »
    Cluso's P2-RetroBlade and P2-MaxiBlade
    Cluso's P2-MaxiBlade
    Identical to the RetroBlade except...
    * VGA connector removed, and in its' place...
    * 2x10 0.1" header with P17-31 plus 3V3 and GND
    Will you be offering these up on your website when they are ready?
  • Looks great ! P2-MaxiBlade for me please.
    edited 2020-10-13 - 12:17:17
    Revised update - thanks for pushing this Peter
    * pcb now 2.2"x1.6" (was 2.0"x1.5")
    * single pcb does both VGA and P16-31 on 0.1" header under the VGA connector
    * adjusted the pitch of P0-15 and P32-47 to 1.5"
    * VGA now uses the top pins P27-31 of the group with P27=VS
    Now, you can solder the P16-31 header to just be on the underside of the pcb if you want to have both VGA and the header :sunglasses:
    Of course now I have to adjust the tracks and fills so this will take day(s)?
    Same price - I'll ship both the 0.1" headers and the VGA connector. Through-hole parts will not be soldered.
    R3 should be 1M
    2020-10-13: First and second post updated with latest
    edited 2020-10-22 - 21:14:44
    Updated the first two posts with the latest design :sunglasses:
    BTW It’s been really quiet on the forums. What are you all up to?
  • PCBs ordered - should be ~2 weeks :sunglasses:
    edited 2020-10-22 - 21:15:53
    PCBs are in the air and hopefully may arrive Monday :sunglasses:
    BTW It’s been really quiet on the forums lately. What have you all been up to?
  • Documentation
  • PublisonPublison Posts: 11,735
    edited 2020-10-22 - 21:34:23
    Cluso99 wrote: »
    Can't wait to see.
    I have noticed the crickets, but spammers behind the scene have not stopped. Off course Van and I shield you guys from all that noise. :)
  • I got your spam.
    800 x 1067 - 241K
  • Nice looking board Ray! Would love to order one
    Been busy with day job (bittersweet that...finally back into a rhythm, but less time for Prop play...isolation was good for that :smiley: ) but still trying to chisel away at a new driver or fix bugs in existing ones, here and there...
    Cheers
  • I actually like SPAM every 3-4 years for one day. Then I think why did I do that. My 5 year anniversary is coming up. If I post again it didn't poison me. :)
    edited 2020-10-26 - 20:28:12
    PCBs arrived. Looking good :sunglasses:
    edited 2020-10-27 - 03:24:58
    Size comparisons.
    My pcb is 0.1” wider and 0.1” longer than the original P2D2.
  • Peter JakackiPeter Jakacki Posts: 9,719
    edited 2020-10-26 - 06:08:40
    Hey Ray, there is still that bug in the forum software when you insert an image and it repeats the link many times, and I always have to go and cut all the extra links manually. But if you are doing it on purpose just to show off, then fair enough :)
  • I posted it from my iPhone. It’s much harder to check for the multiple images bug. I’ll fix it when I’m on my computer in the morning:(
  • Here is what the board will look like with connectors (microSD, 2x microUSB, optional VGA) :sunglasses:
  • Nice, Cluso!
  • Finished 3d printing my pcb frame for holding the pcb while screen printing the paste.
    Printing the paste frame now - holds the paste screen. I have printed a hinge too. Then i will need to align them both and mount on a bread board (for cutting bread).
  • Well done, I will have to try something similar.
  • This is the idea. The frame has a hinge to the piece fastened to a board. Then the pcb frame is mounted to the board in the exact position.
    Here is the frame with the hinge at the top (on the left here as the pic is rotated left). The stainless screen is mounted in the frame.
    I’ve used these hinges before in my LCD to VGA screen and they work nicely.
    edited 2020-10-27 - 07:51:36
    Peter,
    Do you have a 3d printer? If not, what is your panel size(s) to 0.1mm accuracy and I'll make you the pcb mounting.
    Your screen is already in a frame so will need to make some corners for positioning it.
    The main problem is getting the pcb to fit snug in the frame when printed. The printer is not perfectly calibrated so some tweeking is necessary. The forth one I made finally fit perfectly. I'm printing my second screen frame now - expanded 100.1% and it's looking still a shade under-sized :(
