Measuring Skateboard Tilt
13»
  • Duane DegnDuane Degn Posts: 10,393
    edited 2020-09-01 - 18:54:14
    I realized I was running low on black PETG so I printed the front wedge in blue.
    If I were to do this again, I think I'd try to figure out how to get the deck closer to the ground. Here are a couple photos of the Frankenstein board next to the Ownboard.
    The decks are about the same size but the off road trucks make the Frankenstein board long and higher above the ground.
    I need to get the VESC motor controller wired up and attached some how. I'll likely just use some more Gorilla tape for now. Eventually, I'll print an enclosure for the electronics.
    1301 x 528 - 236K
    1236 x 541 - 271K
    1228 x 738 - 436K
