Measurement tools: analog vs digital
potatohead
@Rayman said:
Digital is way better
@"Roy Eltham" said: "Here is a dual unit analog"
@potatohead said: "I make sure I have one good analog tool and perfer them in most cases"
Before we clog @"Ken Gracey" thread, I thought we might have a tool chat.
Digital ones tend to update slowly. This is fine for static measurements, but not so great for dynamic ones.
Batteries... yeah, they go dead. Cheap o calipers tend to have high standby current.
Analogs need care and feeding.
No perfect answer. For me, I love always on. Sort of in the same way paper is always on.
Paper does not have downtime, nor do analog tools.
Go!
The dual unit analogs never felt quite right to me personally.
I bought a $200 ish 12" caliper in 87. Love it, still use it. And I know that tool well.
Have owned a few digital. The one I have now has good standby. I use it for metric measurements sometimes. I like it.
Been there done that.
@"frank freedman" you got a good one. Around the shop here, there are a few analog tools. Mine mostly.
One good digital unit. I like and use it regularly. Several cheap ones that hog down batteries!
One case I like a lot are analog dial indicators. Move them over a surface, for example, and one gets a high fidelity map. The refresh rate and need to mentally compute / convert flashing numbers to geometry is lacking.
Truth be told I no longer have my original tables but I do have my slide rules (two sets)
I still have a set of 3 miniature screwdrivers in pouch that IIRC came on a 1960’s Radio and Hobbies magazine. Use them often as in yesterday on a P1 pcb! Work great when soldering a set of pin stakes reverse way around, then cut the excess, turn over to top of pcb and pry the plastic retainer off the pin header to leave a short set of pins to take the small shunts.
I guess we should be happy we are not sitting on park benches having this kind of discussion about our medical issues 😎 ...........
