Trouble booting full TAQOZ distro from sd
(originally a private thread with Peter Jakacki, moved to the forum in case it helps others)
I was unable to boot the full TAQOZ based on the instructions on the sourceforge page:
> Download the _BOOT_P2.BIX binary and copy this onto the root directory of a FAT32 SD card.
> Insert this into your P2 system and it will automatically boot TAQOZ at 115200,8N1.
> The baud rate may be changed and locked in after booting.
Is there a limit to the FAT32 volume size that the ROM booter will recognize? Is there any way to load the full set of TAQOZ words from the sd card, since the built-in version works?
  • Cluso99Cluso99 Posts: 16,263
    edited 2020-06-07 - 20:46:00
    The SD booter will only look in the first cluster size of directory entries on the SD card. In current sized cards this is 32KB meaning 64 sectors and there are a possible 32 file entries per sector. So the booter will only look at the first 2048 entries for the two boot files _BOOT_P2.BIX and _BOOT_P2.BIY. The filenames must be uppercase.
  • Peter JakackiPeter Jakacki Posts: 9,211
    edited 2020-06-08 - 02:18:33
    Ok, just to triple check I formatted an 8GB SanDisk and downloaded the _BOOT_P2.BIX file from SourceForge using the big DOWNLOAD button on the main page. I copied this file onto the card along with some extra test files and booted my P2 EVAL board with it in. The only thing that might be different is the baud rate which I had defaulted to 921600. I know I used to default to 115200 baud for those funny serial port programs that they sometimes call "terminals" but in hindsight I think that's a mistake and I should encourage a full and proper serial terminal emulator for the full interactive experience. Besides, terminal emulators such as TeraTerm and minicom etc can handle the throughput of very high data rates.
    I noticed that the main page summary mentions 921,600 baud default. Remember too that if you have any hardware problems with the P2, even booting, that you can drop back into TAQOZ in ROM after reset by using the three key auto-bauding sequence "> space escape". From there you can MOUNT the SD card and check it etc. Make sure your DIP switches are off (for now).
    I might change the default download to a zip of the boot file plus a readme.
    Here is what I got from my P2 EVAL and that boot file.
    KERNEL            Parallax P2  *TAQOZ* Extensible Firmware  V2.5 'CHIP' 300MHz 200504-1430
    MODULES:
      *C2*    1518          C2 Debug Interface for Silabs Microcontrollers - 200424.0000
      *SPLAT*    2324       SPLAT - Serial Propeller Logic Analyzer Terminal  200417-0000
      *SIM65*    2880       A SIMULATOR FOR THE 65C02 - 200217.0000
      *PLEXLED*     350     CharliePlexing LED device driver 190714.0000
      *MORSE*     444       Morse code keyer 200126-0000
      *LIFE*    1172        Conway's Game of Life for TAQOZ in the P2 ROM V1.0 190226.0000
      *BREAKOUT*    1506    BREAKOUT FOR THE P2 - 190606
      *MANDELBROT*     518  MANDELBROT VGA DEMO 190800-0000
      *CLKGEN*     654      Si5351 Clock generator 190800-0000
      *EASYNET*    3736     WIZnet NETWORK SERVERS 160707.1500
      *W5500*    2292       WIZNET W5500 driver for TAQOZ V1.0 191007
      *PS2*     654         PS/2 KEYBOARD
      *TEXT*    1508        VGA BMP TEXT 190800-0000
      *BMV*    1260         BMV VIDEO PLAYER 190800-0000
      *WAVE*     772        WAVE AUDIO FILE PLAYER 190800-0000
      *BMP*     430         BMP FILE VIEWER 190800-0000
      *TIM*    1942         TAQOZ INTERACTIVE MEDIA - AUDIO, TEXT, IMAGE & VIDEO DRIVERS 200403-1200
      *TIA*    4866         TAQOZ INTERACTIVE ASSEMBLER for the PARALLAX P2 - 200327-2300
      *SPIRAM*    1248      LY68L6400 8MB SPI RAM ACCESS 191020-0000
      *DECOMPILER*    1762  A decompiler for TAQOZ 190825-0000
      *RTC*     434         RV-3028 RTC DATE and TIME 190800-0000
      *DISK*    2562        SD DISK REPORTING & FORMATTING TOOLS 190800-0000
      *EASYFILE*    4658    SD CARD and FAT32 with VIRTUAL MEMORY  190800-0000
      *SMARTPINS*     374   SMARTPIN FUNCTIONS and drive modes 190800-0000
      *P2CLOCK*     384     P2 CLOCK CONTROL 190800-0000
      *ANSI*    2286        ANSI TERMINAL SUPPORT 200410-0000
      *EXTEND*     390      Primary kernel extensions 200426-1000
      *SPIFLASH*    5746
    MEMORY MAP
      CODE:         0DE78  56,952 bytes
      WORDS:        1A592  22,984 bytes
      DATA:         7E2B1  689 bytes
      ROOM:                50,970 bytes
    HARDWARE
      PCB           P2
      CLOCK IN      20MHZ
    DEVICES
      SD CARD       63 GB  SANDISK   SD SC64G REV$80 #35190404 DATE:2018 /10
      SPI FLASH     16MB WINBOND $EF70_1800 #1084004282818649332
    I2C DEVICES
    TAQOZ#
    and this is the status line in minicom:
    CTRL-A Z for help | 921600 8N1 | NOR | Minicom 2.7.1 | VT102 | Online 12:36 | ttyUSB0
  • I can also verify that the Soundforge file works fine. I downloaded this morning to a SanDisk 64Meg formated to FAT 32.
    Here is my listing:
    MODULES:
      *SPIFLASH*    5746
    MEMORY MAP
      ROOM:                50,970 bytes
    HARDWARE
      PCB           P2
      CLOCK IN      20MHZ
    DEVICES
    I2C DEVICES
    TAQOZ#
    I'm runing TeraTerm at 921600.
  • I've gotten the download running from a 16GB (MicroCenter generic brand) SD card formatted with FAT32 on a MacBook Pro. Terminal program is CoolTerm at 921600 Baud.
    KERNEL
    ..  Parallax P2  *TAQOZ* Extensible Firmware  V2.5 'CHIP' 300MHz 200504-1430
    MODULES:
      *C2*    1518
    ...C2 Debug Interface for Silabs Microcontrollers - 200424.0000
      *SPLAT*    2324
    ...SPLAT - Serial Propeller Logic Analyzer Terminal  200417-0000
      *SIM65*    2880
    ...A SIMULATOR FOR THE 65C02 - 200217.0000
      *PLEXLED*     350
    ...CharliePlexing LED device driver 190714.0000
      *MORSE*     444
    ...Morse code keyer 200126-0000
      *LIFE*    1172
    ...Conway's Game of Life for TAQOZ in the P2 ROM V1.0 190226.0000
      *BREAKOUT*    1506
    ...BREAKOUT FOR THE P2 - 190606
      *MANDELBROT*     518
    ...MANDELBROT VGA DEMO 190800-0000
      *CLKGEN*     654
    ...Si5351 Clock generator 190800-0000
      *EASYNET*    3736
    ...WIZnet NETWORK SERVERS 160707.1500
      *W5500*    2292
    ...WIZNET W5500 driver for TAQOZ V1.0 191007
      *PS2*     654
    ...PS/2 KEYBOARD
      *TEXT*    1508
    ...VGA BMP TEXT 190800-0000
      *BMV*    1260
    ...BMV VIDEO PLAYER 190800-0000
      *WAVE*     772
    ...WAVE AUDIO FILE PLAYER 190800-0000
      *BMP*     430
    ...BMP FILE VIEWER 190800-0000
      *TIM*    1942
    ...TAQOZ INTERACTIVE MEDIA - AUDIO, TEXT, IMAGE & VIDEO DRIVERS 200403-1200
      *TIA*    4866
    ...TAQOZ INTERACTIVE ASSEMBLER for the PARALLAX P2 - 200327-2300
      *SPIRAM*    1248
    ...LY68L6400 8MB SPI RAM ACCESS 191020-0000
      *DECOMPILER*    1762
    ...A decompiler for TAQOZ 190825-0000
      *RTC*     434
    ...RV-3028 RTC DATE and TIME 190800-0000
      *DISK*    2562
    ...SD DISK REPORTING & FORMATTING TOOLS 190800-0000
      *EASYFILE*    4658
    ...SD CARD and FAT32 with VIRTUAL MEMORY  190800-0000
      *SMARTPINS*     374
    ...SMARTPIN FUNCTIONS and drive modes 190800-0000
      *P2CLOCK*     384
    ...P2 CLOCK CONTROL 190800-0000
      *ANSI*    2286
    ...ANSI TERMINAL SUPPORT 200410-0000
      *EXTEND*     390
    ...Primary kernel extensions 200426-1000
      *SPIFLASH*    5746
    MEMORY MAP
      CODE:
    ..0DE78  56,952 bytes
      WORDS:
    ..1A592  22,984 bytes
      DATA:
    ..7E2B1  689 bytes
      ROOM:
    ..       50,970 bytes
    HARDWARE
      PCB
    ..P2
      CLOCK IN
    ..20MHZ
    DEVICES
      SD CARD
    ..63 GB  SANDISK   SD SC64G REV$80 #35190404 DATE:2018 /10
    I2C DEVICES
    TAQOZ#
    edited 2020-06-09 - 00:06:40
    Hey Mike, it looks like CoolTerm is dropping characters at that baud rate. You can dial down to any baud rate to try that again to see if it works properly, then backup the settings like this:
    115200 CONBAUD
    Then change the terminal to 115200 to match and check it responds, and then try ?? for the sysinfo report.
    If all is well you can backup to the same bix file using this shortform version:
    BACKUP BIX
    Do this anytime you want to save settings and code between powerups.
    Alternatively, you could try minicom which I believe can run on Macs. It looks basic since it doesn't have a GUI but it works a lot better than most nice looking terminal emulators I have running in Linux. I have a shell command in Linux called "usb" to connect to my serial usb devices easily.
    minicom --color=on -w -b 921600 -D /dev/ttyUSB$1
  • I was able to change Baud to 115200, but the output doesn't seem to look any different:
    TAQOZ# 115200 CONBAUD --- ...ÄÄÄÄÄÄÄÄÄ..Ä..ÄÄÄÄ.ÄÄ.ÄÄÄ.Ä.ÄÄÄÄ....?? ---
    KERNEL
    MODULES:
      *C2*    1518
      *SPLAT*    2324
      *SIM65*    2880
      *PLEXLED*     350
      *MORSE*     444
      *LIFE*    1172
      *BREAKOUT*    1506
      *MANDELBROT*     518
      *CLKGEN*     654
      *EASYNET*    3736
      *W5500*    2292
      *PS2*     654
    ...PS/2 KEYBOARD
      *TEXT*    1508
      *BMV*    1260
      *WAVE*     772
      *BMP*     430
      *TIM*    1942
      *TIA*    4866
      *SPIRAM*    1248
      *DECOMPILER*    1762
      *RTC*     434
      *DISK*    2562
      *EASYFILE*    4658
      *SMARTPINS*     374
      *P2CLOCK*     384
      *ANSI*    2286
      *EXTEND*     390
      *SPIFLASH*    5746
    MEMORY MAP
      CODE:
      WORDS:
      DATA:
    ..7E2B1  689 bytes
      ROOM:
    ..       50,970 bytes
    HARDWARE
      PCB
    ..P2
      CLOCK IN
    ..20MHZ
    DEVICES
      SD CARD
    I2C DEVICES
     ok
    TAQOZ# BACKUP BIX ERROR! ---  ok
    TAQOZ
    As far as I can tell, Minicom does not run under MacOS. CoolTerm seems to work well at least up to 230400 Baud.
    edited 2020-06-09 - 03:59:14
    Seems like CoolTerm is still having a problem keeping up, but maybe more so with new lines. You can manually patch an end-of-line delay that I had in that version like this:
    20 $20B8 C!
    This will change the default value of 1ms to 20, then check it with ?? and increase until it looks right then backup.
    I've found a 64-bit version of CoolTerm for Linux that I am checking out now but notice it says that it is not a Terminal Emulator, but a terminal application, although I don't use any ANSI codes at startup.
    edit: I don't know if this 64-bit build for Linux is the same, but it's a terrible terminal! Anyway, besides this weird screen rescrolling thing, the settings are defaulted to 100ms refresh which seems to be a problem with the program's implementation. It shouldn't need this, but lowering doesn't help and it seems it is interpreting a CR, not as a return to the left, but as a new-line, and I can't find anywhere to change that. There doesn't seem to be any ASCII code that can clear the screen either, that's a huge oversight. Normally $0C as FF does the trick.
    TeraTerm etc can do newline on CR if need be, but only as an option because terminal emulators normally only return to the left column.
    BTW - how I got that magic number:
    TAQOZ# SEE CRLF
    1F909: pub CRLF
    020AC: 20BE     CR
    020AE: 180A     10
    020B0: 2002     EMIT
    020B2: 1E10     REG $10
    020B4: 00EC     W@
    020B6: 005F     ?EXIT
    020B8: 1801     1
    020BA: 0F24     ms
    020BC: 005D     ;
          18  bytes
     ---  ok
    TAQOZ# 20 $20B8 C! ---  ok
    You can do another SEE CRLF to see the change.
  • Hi Mike, I use Serial2.app on my IMac. It works great up to 3 Mbaud.
    @peter, is there a serial terminal emulation in Visual Studio? Or can you please explain your workflow in Visual Studio.
  • It seems the Mac environment is filled with "try before you buy" software that is better elsewhere and it's free. However I use minicom on Linux and apparently you can install that on your Mac to "try and never buy".
    So if you also install the free VSC you can open a terminal shell in there and invoke minicom.
    3168 x 1912 - 898K
  • Sorry, all. I totally dropped off the face of the Earth for a bit. I'll reformat my sdcard and try again.
  • Help!
    I have been consistently unable to boot TAQOZ from SD on my P2ES rev B.
    I have SanDisk 16GB loaded with _BOOT_P2.BIX. Do i need to set any boot switches?
    I can boot the firmware TAQOZ. Mount works. How do I boot to SD from there? (Hopefully I am just missing something simple...)
  • PublisonPublison Posts: 11,430
    edited 2020-06-17 - 17:06:27
    I downloaded Peter's latest from
    https://sourceforge.net/projects/tachyon-forth/
    to a 8Gb uSD card, and it worked fine on my Rev B.
    All switches in OFF position. Try cycling the switch from OFF to ON to OFF.
    Make sure uSD is formatted FAT32.
    Also see above where I installed on 64 Gb and had good install. TeraTerm worked at high baud rates.
  • Downloaded the latest build. Put it on a 16gb SanDisk. Booted ok. Default bait rate was above 900k. Putty was unable to keep up. Teraterm was working good
    On the boot screen system told me my sandisk must be 64gb.
    Think there is a bug in disk size calculation
    Ps reformatted my sandisk with fat32 on windows. Was exfat.
  • Yes...
    I have done all that.
    Still no boot on reset.
    Windows 10
    TerraTerm 921600 8 n 1
    16GB SanDisk
    FAT formatted
    Latest _BOOT_P2.BIX copied to the blank card.
    The firmware version allows me to Mount the card successfully.
    TAQOZ# MOUNT --- .SDSC16G 73FD_23AD TAQOZ 32k 15,189M ok
    It allows me to DIR the card successfully.
    Are there any TAQOZ words I can use to debug this?
    Do I have a bad P2ES rev B board?
    I am getting frustrated....
  • You say formatted to FAT is that FAT32?
    edited 2020-06-17 - 22:12:36
    DaveJenson wrote: »
    Yes...
    Windows 10
    16GB SanDisk
    FAT formatted
    I've double checked and double checked the download from my SourceForge link, and it works. I had someone else download an older version from somewhere and it didn't work.
    Don't use old 2GB SD cards, use SDHC formatted to FAT32. Windows will not format a 64GB card to FAT32, it formats to exFAT even though it says "FAT".
    I will see if I can use the p2 loader to load the whole 128k image because once you have TAQOZ up and running it is very easy for TAQOZ to format a 64GB card to FAT32.
    I found I needed to rename _BOOT_P2.BIX to a .bin file and it worked. Once you have any kind of SDHC card in there the easiest way to back it up to the MBR area by hitting ^B (control B). This will always work and maybe if it didn't work the first time because it hadn't been mounted or something, just try it again. This will always save to sector 1 onwards which is normally hidden on preformatted cards although Windows tends to ignore the SD spec and not leave any hidden sectors.
    08:01 TAQOZ$ python3 loadp2.py _BOOT_P2
    Python Prop2 loader Ver 1.2 14th Jan 2019 - ozpropdev
    Python version: 3.6.9 (default, Apr 18 2020, 01:56:04)
    [GCC 8.4.0]
    Scanning ports....
    /dev/ttyUSB0 = Prop_Ver G
    Project =  _BOOT_P2.bin on /dev/ttyUSB0
    HUBSET #1 Ok
    HUBSET #2 Ok
    Loading TXT ....complete
    �����C` ---  ok
    TAQOZ# ?? ---
    MODULES:
      *SPIFLASH*    5746
    MEMORY MAP
      ROOM:                50,970 bytes
    HARDWARE
      PCB           P2      (P2D2)
      CLOCK IN      20MHZ
    DEVICES
      SPI FLASH     16MB WINBOND $EF40_1800 #4837448895114529879
    I2C DEVICES
      $36           MCP9808 TEMPERATURE SENSOR
      $A4           RV-3028 RTC
      $C4           Si5351A CLOCK GEN
                    2000/01/01 .." 00:03:49
     ok
    TAQOZ#
  • bartgranthambartgrantham Posts: 80
    edited 2020-06-18 - 05:21:09
    I've figured out my problem. To my surprise, neither minicom nor screen on macOS can handle 921600 baud, despite showing that they can. CoolTerm _does_ work, thanks for the suggestion @Mike Green!
    @DaveJenson : TAQOZ immediately shows a boot prompt if it works. If you're seeing gibberish you have the same mismatched baud rate problem I did.
    @Peter Jakacki : is there a way to load the TAZOQ words into the dictionary from the .bin (.bix) file on the sd? ie. boot P2 normally, "> ESC" for the ROM TAQOZ, and then a word or two to load the full version? The reason I suggest this is that bootstrapping to SD is at least three things to go wrong: SD/FAT32 access, baud rate support in the term, loading TAQOZ itself. If any of those don't work a user is flying completely blind. If there was a way to load the full version while using the built-in ROM that would help a user triangulate the problem. (it was also the first debugging thing I thought of, but couldn't find a way to do it)
    edited 2020-06-18 - 06:58:06
    More term testing, everyone's mileage may vary:
    picocom works well on macOS and two flavors of Linux (Mint and Solus): picocom -b 921600 -d 8 -p 1 -y n /dev/$SERIAL
    screen works well on Linux (Mint and Solus): screen /dev/$SERIAL 921600
    minicom works on Linux Mint*: minicom -b 921600 -D /dev/$SERIAL
    * it's not in the Solus repo: rejected by the distro because minicom is no longer being updated
    (minicom and picocom were both installed on macOS 10.14.6 via homebrew (screen is built-in) ; all three were installed on Linux Mint via apt ; picocom and screen were installed on Solus via the Software Center)
  • Well, here is the newest info.
    When I run FlexGui (ver 4.2.1) or Propeller Tool (2.0.0.1 Alpha)
    and try to search for a P2 com port it works perfectly
    UNTIL I PLUG IN AN SD CARD!
    then both programs fail to find the P2 on any port.
    I think I need to send it to Parallax to see if I got a bad one....
  • When I use pnut I need the serial switch on to prevent looking for the sd card. IIRC it’s 59v 59 pull down. Loadp2 works just fine, so it’s a timing issue with pnut and probably PropTool too.
  • First let me tell you what a great company Parallax is! (You all know that, though!)
    I was frustrated enough with the non-ability to boot from SD that I sent it to Parallax for repair. Turns out that I wasn't crazy. There is a problem with that board booting from SD!
    Parallax sent me a replacement P2ES.
    Thank you, Parallax! Now I can play along again!
    edited 2020-06-29 - 19:23:22
    Woot! Come play. The waters fine. 😁
