String with quotion mark in Full Duplex Serial — Parallax Forums
Got stuck.. no problem in Parallax Serial Terminal but how do I send a string like this in FDS:
AT+CGDCONT=1,"IP","NetProvider"
    edited 2020-06-19 19:55
    fds.str(string("AT+CGDCONT=1,",34,"IP",34,",",34,"NetProvider",34))
    34 is the ASCII decimal value for a double quote.
  • msrobotsmsrobots Posts: 3,701
    edited 2020-06-19 20:30
    in spin that would be
    fds.str(STRING("AT+CGDCONT=1,",34,"IP",34,",", 34,"NetProvider",34))
    my guess, not tested.
  • Awesome!
    Works perfect!
    Thank you so much!
    edited 2020-06-19 20:34
    actually I had to fix the post, you need a final ,34 at the end of the string command
    and @"Phil Pilgrim (PhiPi)" beat me by minutes...
  • msrobots wrote: »
    No problem, thanks to both of you. It was just before I started to modify the FDS with a PUB Char.
    And the solution was just seconds away thanks to this powerful forum.
