SimpleIDE error: "Download failed: -1"
in Propeller 1
I just installed SimpleIDE 1.1.2 and tried to run the Welcome project. The Build Status window says the build succeeded, but then this:
I do have a working Propeller on COM3 (verified with PropTool). This is on Windows 10. I have tried restarting my computer.
Help?
proploader.exe -r -I C:/Program Files (x86)/SimpleIDE/bin/../propeller-gcc/propeller-load/ -b activityboard -p COM3 Welcome.elf
Opening file 'Welcome.elf'
ERROR: Download failed: -1
Help?
What propeller are you using? Prop Mini or flip. For some reason it can't talk serially to the device.
It would be nice if the error code were a little more informative so I could determine if it's the chewing gum or the baling wire causing my problem.
m
If it's your own design then it probably is a reset issue since that seems to be a common problem when building your own.
