Propscope Calibration
I recently picked up a new in the box Propscope on eBay for a price I couldn't resist. Going though the understanding signals text and It seems the calibration is off.
Trying to run Activity #1 Ground Test Chanel 1 reports 38.9mV and channel 2 is alternating between 19.5mV and 39mV. It should be showing 0 volts.
Same thing happens with removing the probes from the scope.
I cant find any information on calibration. Did I get a dud or is this fixable ?
Well after hooking my unit up and shorting the leads I see a reading of 24mv and 26.8mv. Since I don't use my scope to read voltages I never checked that.
"Note: It is recommended that current Propeller users upgrade the Propeller Tool to version 1.2.7 or higher, to prevent conflicts with the PropScope."
The most current version is 1.3.2 and can be found here - https://www.parallax.com/downloads/propeller-tool-software-windows-spin-assembly
It would not hurt to make sure you have the most current version of the PropScope USB Oscilloscope Software - you can find version 2.07 here - https://www.parallax.com/downloads/propscope-usb-oscilloscope-software
If you still have issues, I recommend you contact Parallax Tech Support. They should be able to help you sort this out.
