Need precision divider resistors
Phil Pilgrim (PhiPi)
A friend of mine is refurbishing a large vessel for commercial fishing. He bought a digital panel meter that accepts voltage inputs to 200mV full scale. He needs 2V full scale. The module includes pads for a voltage divider, along with decimal-point-selector pads. To accomplish his requirements, the doc sheet that came with the meter specifies two ½W, 0.05%, metal-film resistors valued at 1 Megohm and 9 Megohms. Surely DigiKey or Mouser must have such things in their immense Ohmic bestiaries, right?
Nope. I'm at a loss. Any ideas where I can find such resistors in stock and ready to ship in onesie-twosie quantities?
https://www.goldmine-elec-products.com/prodinfo.asp?number=G21520
https://www.goldmine-elec-products.com/prodinfo.asp?number=G22848
in series.
.05% seems pretty tight for a panel meter.
Digikey has them too. You'd have to "bend" it to fit the existing pads.
More than likely that meter uses a 7106/7107 as do a lot of cheap meters.
Does the meter have over 2,000M Ohms input impedance ?
The module includes a trimpot to compensate for slight calibration discrepancies. I plan to use it, along with my Agilent precision voltmeter, to adjust the calibration over a range of inputs in order to minimize the RMS error.
