How to clamp an input signal to propeller?
2»
  • Tracy AllenTracy Allen Posts: 6,475
    edited 2020-05-18 - 18:08:39
    About the wire stub in the picture, I see that it exits through a hole in the back of the box. How does it get from there to the Prop input, how far? It doesn't look like coax, but it could be, with the shield to fix the ground point right on the box, and the center wire to form the pickup stub. Then the bias established by the voltage divider sets the operating point at the Propeller. You can include the additional 100pF capacitor, but the 8.8pF already provides isolation.
    Are other ground connections between the Prop and the system, say, from the directional coupler? That kind of complication along with grounds to measuring instruments can create loads of confusion!
    8.8pF has a reactance of around 600Ω at 30Mhz, so it is not capable of injecting a lot of current into the Prop. If I were to put Schottky diodes on an SMT circuit board, I'd probably choose a head to tail dual, something like a BAT54.
  • jcfjrjcfjr Posts: 41
    edited 2020-05-19 - 19:42:54
    It is coax, and I do not have the shield grounded to anything. I had it grounded, but the signal into the prop was too weak to measure. Once it goes into the hole you see, it is about 2 inches of coax to my board, then a one inch trace into the prop.
    The prop ground is common to throughout the system except for the 24v for the motors, it uses a separate ground. Ground is common to directional coupler and tuner. Coax shield acts as ground connecting antenna, tuner, coupler, transmitter.
    Something like attached picture, with no additional coupling cap?
    edited 2020-05-19 - 21:08:58
    The circuit is fine, but I'd want to emphasize that Vdd to Vss needs to be bypassed with a low ESR capacitor right at the point where the diodes connect.
    It wouldn't hurt to include the additional 100pF capacitor in series with the 1kΩ resistor, just in case by some mistake the input signal happens to touch the feed line. Ouch! Don't want the Prop to connect to a 1000W xmtr!
    RG174 coax presents about 30pF per foot, and the short length you have, say 10pF. If that is connected to ground, it would act as a capacitive voltage divider referenced to Vss. Maybe that is why the signal was too weak to measure when the coax was grounded. A resistive voltage divider to the center conductor should be able to pull the signal up to near the switching threshold, with or without the shield grounded. Have to solve the circuit, the signal source to load impedance.
  • A low ESR capacitor is new to me. The only caps with a ESR rating at Digikey are electrolytic, and the smallest one is 2.2uf. This seems too high. Can you suggest a type and capacitance that I should use to bypass Vdd to Vss? Should this be a SMT also? When you say a resistive divider to the center conductor, are we back to the original design with resistors as Ariba suggested earlier in this thread? I don't know how to solve circuit signal source to load impedance. My new boards are to arrive today that are designed to the first idea of a resistor divider, so I will populate this board and do some testing.
  • Oh, the capacitor would be an X5R or X7R ceramic type, which as a class have low ESR. Maybe you have 0.1uF SMT ceramics already on your circuit board? That's it. The idea is to have one across the supply close to the where the diodes attach. The diodes will dump excess current into that capacitor, like fast in and out.
    Yes, the circuit that Ariba suggested above. Be prepared to experiment with the 12kΩ value, to tweak it for sensitivity.
    As he pointed out, the chip itself does have protection (substrate) diodes that can shunt excess voltage and current over to the power supply. Power supply bypass capacitors are critical. If you go for adding the Schottky diodes, they have a lower threshold voltage and will shunt the current away from the Prop. Security blanket. The 100pF capacitor is not necessary, but it is a good addition for safety. 100pF in series with 8.8pF is still 8.8pF.
    The 12k / 10k divider has an effective parallel impedance of 5.5kΩ (10*12/(10+12)) when it loads the signal, with a bias of 1.5V (=3.3 * 10/(10+12)). The signal comes in via the 8.8pF, the reactance of which varies with frequency, from 5050Ω at 3.5Mhz to 620Ω at 28.5MHz (1/2piFC). On that basis, more signal will pass through at the high end of your frequency range. That analysis is not the whole story though. There is also stray capacitance and inductance, and if you add in capacitance of Schottky diodes, the capacitance of those would tend to level out the response at high frequencies. And when you measure those voltages, the probes themselves likely affect the outcome.
